Fuse instead of Relay?
I checked my fuse box in the front compartment and it seems that I'm missing the fuel pump relay; instead, there's a fuse (the usual flat ones with 2 heads).
This was probably done by some mechanic that worked on my car during the restoration process, but I have no idea why he did it and the effects it has on engine performance. Is it ok to leave it there or replace it with a proper round relay?
Old 06-20-2009, 08:26 AM
You need to tell us the year and model of car. Assuming you have a CIS car, the earlier models (up to at least 75, maybe a few years more) did not have a relay and the fuel pump started with the turn on the ignition key. Your car may be correctly wired, but we need to know a bit more detail.
(Hint: post your car information in your signature line, that way any time you have a question, everyone will know the basics.)
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-20-2009, 08:34 AM
1989 911
Old 06-20-2009, 08:13 PM
1989 911
Motronic cars have the fuel pump controlled by the DME under the seat, and the relay lives under the seat with it.
The DME relay gets flaky a lot more often than the round ones - carry a spare.
'77 S with '78 930 power and a few other things.
Old 06-20-2009, 11:34 PM
