sway-bar mount keeps breaking
I have 22 mm Weltmeister f/r sway-bars on my '79 911 and I just broke off the rear mount. This was a reinforced mount, the original broke a while ago. The car also has 22/28 mm torsion bars. I usually run the rear bar almost fully tight. I have two questions:
1. What should I do so that I do not have this problem again?
2. Is running the sway-bar at full stiffness a bad idea?
Thank you for reading
Old 06-25-2009, 11:07 AM
Driver8's Avatar
Are you running reinforced mounts on both sides? What brand reinforced mounts are you using?
Old 06-25-2009, 11:09 AM
Yes, I am running reinforced mounts, I believe they are Weltmeister.
Old 06-25-2009, 11:32 AM
PRO Motorsports
Tyson Schmidt's Avatar
Buy the Wevo rear mounts. Pelican sells them.
Absolutely bulletproof.
Another great WEVO product: rear swaybar mounts
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-25-2009, 11:42 AM
tobluforu's Avatar
..and then add the welt mounts for the torsion tube as a back up.
Old 06-25-2009, 01:53 PM
3.4 Bigger is better
88-diamondblue's Avatar
The reinforced mounts are still just sheet metal. Use the Wevo for the last time. If they come loose it will be sheet metal tearing away as these are cast steel
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 06-25-2009, 02:38 PM
I wonder if you ran a thicker rear torsion bar if it would solve some of the problem?
Old 06-25-2009, 02:46 PM
I have stiffer torsion bars and both mounts were welded twice before I replaced them with the Wevo. The factory mounts are sheet metal and just not up to the task. Doesn't make any difference if you just drive on the street or track the mount will eventually break.
Michael
2020 Honda Passport
Old 06-25-2009, 02:56 PM
PRO Motorsports
It helps.
The worst offenders were the late Carreras with their larger sway bars, but still soft torsions, and most came with the wimpy Boge Turbo Gas shocks and struts. That put a lot of load on the sways.
2004 GT3
Old 06-25-2009, 02:58 PM
Wevo mounts it is, thank you all for the help.
With respect to:
can you specify what this refers to?
Old 06-26-2009, 02:01 PM
cycling has-been
bkreigsr's Avatar
sounds like the bar is pre-stressed.
do you have to muscle onto the drop links when attaching it?
the holes in the ends of the bar should line up with the drop link ends and just bolt right on.
years of road/track use can alter the factory body and suspension alignment and cause the placement to vary side-to-side.
Bill K
Old 06-27-2009, 08:22 AM
Brotok,
I'm thinking of adding on a rear sway bar to my car and here's a list of great threads about replacing sway bar mounts.
Hope this helps.
Minimum ARB to Gearbox Clearance
WEVO Sway Bar Bracket Install mod
Rear sway bar bracket broken, help!
WEVO Rear Anti-Rollbar Console Install
Old 06-27-2009, 09:17 AM
tobluforu's Avatar
With respect to:
Weltmeister has mounts that attach to the rear torsion tubes if one does not have the mounts welded in place. The welts torsion tube mounts are farther in which can cause the bar to flex more so most do not use them, I do and have had them for 15 years with out any issues. But you could add them so you have double the strength.
Old 06-27-2009, 10:29 AM
avendlerdp's Avatar
Hey, take a look at the side of the "frame" member that you are welding to. It's pretty thin. I added a doubler to it. Just a piece of sheetmetal with a lot of holes drilled in it. Stitch weld it on there then tack all the holes through to the metal on the car. THEN weld on your new mounts. It's bit more time but worth it.
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 06-27-2009, 10:35 AM
Retired Member
Brian 162's Avatar
I have the same sway bar on my car. The part that the sway bar link attaches to the torsion plate breaks. The left one broke last year and the right side broke this year.
Sorry to hijack, any ideas??
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 06-28-2009, 05:48 PM
