Guest
Posts: n/a
2.2 & 2.4 cam questions
what is the difference in the 2.2T and 2.4T cams between the two motors. Also is there any differences in the heads. I am finishing my 2.2 and was wondering.
Guest
Posts: n/a
Assuming you are comparing the ROW 2.4 'T' with carbs, no difference at all!
If you are really asking if it is feasible to convert your 'T' to MFI, the heads would need to have metal built-up by Heli-Arc welding, then bored, tapped, and milled flat for an injector port. The left cam can be 'adapted' to drive an MFI injection pump. ------------------ Warren Hall 1973 911S Targa [This message has been edited by Early_S_Man (edited 01-29-2001).] |
