What should a rebuilt 915 feel like
I just had the 915 in my 84 3.2 rebuilt by a very reputable and well known shop in northern california. My question to the group is what should it feel like? The car shifts authoritatively from 1-2. 2-3 feels slightly less authoritative and sometimes feels like it is slightly resistant and 3-4 sometimes feels like it just doesn't want to go in to gear. 4-5 works well. Is this normal? Are my synchros "getting worn in"? What should the feeling be?
1984 3.2 targa |
Bill is Dead.
It should feel like moving a stick that's jammed down in a bucket of rocks.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Also, as a part of every 915 repair that we did, we evaluated the shifter bushings and coupler adjustment and made any changes that were necessary.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 06-27-2009 at 12:10 PM.. |
And a properly adjusted clutch works wonders in a 915.
Bruce |
<insert witty title here>
I rebuilt mine, and even though I'm no pro, I could see how it all went together, and why it's not the smoothest or most precise shifting transmission in the world. Even at its best, there will be play in the gear shifter, much sloppier than what we're used to in modern cars. The gear engagement just isn't as precise because of this. Mine shifts slowly from 1st to 2nd, quite quickly and smoothly from 2nd to 3rd, and needs to be very precise from 3rd into 4th, though a better coupler adjustment would help that a lot. (no 5th on mine)
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Air Cooled Addict
+1 with Christien!
Just rebuilt mine about 1k miles ago and fourth can be a little temperamental on up and downshifts (I've got a 5 speed). It seems that the design is better suited to tractors and assembly line equipment than a fine German automobile. I've read that some of the sloppiness can be addressed with a PSJ coupler. This sloppiness or slack seems to be necessary in order to keep the engine/transmission assembly from vibrating your hand off.
Joe V '84 Schwartz 911 Carrera 3.2 '91 Specialized S-Works M2 - Gone but not forgotten '12 Trek X-Cal : American Classic - XT brakes/shifters/derailleurs - carbon goodies '13 Trek Madone 5.2 stockish |
Large Registered Member
Mine felt like a G50 right after being rebuilt!
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
How funny is that!!!!!
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Mine is as smooth as any other transmission after rebuild, granted I had a shop do it, but I don't have any issues with 3rd to 4th and etc.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Was told this would happen and just make sure you're shifting at over 3.5k and moving correctly with the lag and don't be afraid to push it in. and use Swepco even for first 500 mile [which some guys go through pains about aka $50 for a 2 tank run]
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Immature Member
The installed diameter of the synchro rings on the synchro hubs is critical. It's been my experience that even new rings on new hubs with new sliders can vary in feel and resistance to shifting. There is a tolerance allowable, and if that particular gear is at the outside maximum it will feel a bit balkier than a set that is at the smaller end. As things wear it may become smoother shifting. In your description, if it is balky going 3-4 and also 5-4 I suspect your 4th synchro may be on the larger side of the tolerance. This could also happen if the shop just flipped the old synchro ring over (Hopefully they didn't). As long as it doesn't 'crunch' when you shift or resist to the point where you can't shift at all it isn't doing any harm.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Try adjusting the shift coupler linkage. I put in another transmission and I had the same problem, hard to shift into 3rd and 4 th. Adjust coupler very slightly to right (passenger side) and then try shifting. Mine now works great.
Carl Selden 64 356 C + 73.5 Targa -, 73.5 911 Targa - 65 356 C -,63 356 B - 75 911S Targa - |
response of the year! |
