grrr. I'm getting annoyed at this double post stuff already...
T-Shirt wearing, sticker toting, SCWDP registered member ![]() Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it ![]() '83 911sc ROW Targa '84 BMW 320i (what did I get myself into?!) Last edited by gulkster; 07-01-2009 at 09:21 AM.. Reason: double post |
no, what are you using to remove the plugs? i use a standard craftsman plug socket with a swivel and a short extension. check to make sure nothing has fallen down in there keeping the socket from going on.
I'm using the exact same thing, craftsman socket, swivel and short extension. I guess I will need a mirror to see if there is something down there. I hadn't thought of that. thanks.
Jamie
T-Shirt wearing, sticker toting, SCWDP registered member ![]() Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it ![]() '83 911sc ROW Targa '84 BMW 320i (what did I get myself into?!) |
Make sure there's nothing stuck on the porcelain part of the plug, like an old spark plug rubber insert.
Try using a SP socket without an insert and see if it goes deep enough to engage the hex. If so, be careful to extract the plug without dropping it into the engine recesses. A powerful magnetic p/u tool will be handy. Hope this helps, Sherwood |
Mo money = mo parts
Here is an option for compression/leak down testing for the spark plug well on a 911 or any other ohv/ohc car with a deep plug well.
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=27885&utm_source=googlebase&utm_medium=cse&utm_term=INN7881&utm_campaign=googlebase_18u yes, it's $15 + s&h, but if you spend $50 - $60 on a tester and $20 for the extension, it pays for itself in one use and next time it will be free. for the guys that are innovative enough and have the time to make their own tools, I salute you. for the rest of us, this is still a good deal.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
A regular deep socket may not have enough room inside to accommodate the entire spark plug. If so, try a regular spark plug socket w/o the insert.
Sherwood Last edited by 911pcars; 07-01-2009 at 11:27 AM.. |
80 911 SC, Orem, Ut
Also when replacing the plugs, I kept having a problem with my socket coming off in the hole and having to try and fish it out.
So I wrapped the socket and Universal adapter with duct tape and everything came out perfect.
Rob 1980 911 SC |
I never thought about the regular deep socket not having enough room. It was fine in the other five, but #1 does seem a bit more awkward.
That is a great idea. I was having to fish out the socket with needle nose pliers. I was planning on just welding the extension on, as fishing it out takes forever.
#1 plug
I'm having the same problem. Did you figure out how to get the #1 plug off? - Andrew |
Jamie
Figured out the plugs
I was able to get all the plugs out except for number 6. Bought a universal joint and that solved my problem. You really can't orientate the sockets on the plugs unless you have this flexibility.
- Andrew |
