electrical guage issue
I posted before about my car over heating and having no oil pressure and the advice you gave me was to check oil pressure with an oil pressure gauge and to check temp with a gauge. i did that and found out that my fuel pressure was perfect and my temp never went above 220 F and stayed at an average temp of 200 F. So i bought new gauges and put them in and still had the same problem temp gauge went into the red and oil pressure stayed bellow 10 psi. what could cause that to happen.
muck-raker
either the sending unit, or a grounding issue.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I would suspect ground issue as 2 gages are affected.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
Check the sender connections. my oil pressure was reading very high, until I cleaned the connections. Quick fix.
Regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
ground wire on the back of pressure gauge was supposed to be on the temp gauge. all fixed now thanks.
