Do I have to split the case?
Do I have to split the case to replace the wristpin bushing (in order to remove the rod)
I nicked it good trying to get the piston pin out.
Thanks,
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 07-18-2009, 01:03 PM
not nessarily but if youre that far down reseal the case any way.
Rod bushing, put the pin back in fit it because the pin floats so it only has to be free.
Bruce
Old 07-18-2009, 01:35 PM
kodioneill's Avatar
That's a "wrist pin bushing" not a rod bushing.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 07-18-2009, 01:52 PM
Scott R's Avatar
At this point you need machine work on the rod, best to split the sucker and do it right. Have them all re-bushed and balanced, it's the only way to be sure.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-18-2009, 01:55 PM
Yea, Bruce I'm getting pretty far down aren't I.
Splitting the case will definitely make things 100%.
I suspect the #8 o-ring is as worn as the others and thats the only way to get to it.
Also contamination while tearing down is a thought.
I could also check the bearings while I'm in there.
The thing is the car ran great (besides oil leaks) until I discovered the broken head stud.
Thanks,
Leakproof.
Suspected track car
Old 07-18-2009, 01:59 PM
Scott R's Avatar
It's piece of mind at this point, add some ARP rod bolts and coated bearings, you can call them "modifications" if it helps ease the pain of splitting the case.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-18-2009, 02:01 PM
Warren Hall Student
Bobboloo's Avatar
You can remove the rod without splitting the case. Since the nick is on the edge it's not a big deal. I would just take down the high spots with a rat tail file.
I would make the decision on whether or not to split the case depending on the miles on the bottom end. If it's got a ton of miles then the bottom end will need rebuilding anyway. If it's low miles then why create more work when it's not necessary?
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 07-18-2009, 02:38 PM
grateful user
don gilbert's Avatar
you could clean that up with emory cloth
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-18-2009, 03:33 PM
AutoBahned
RWebb's Avatar
how many miles on your '79??
maybe it is nearly time to split the case anyway
Old 07-18-2009, 06:41 PM
Sorry guys, I should no better when asking for your valued advice. 109,893 on the clock.
Suspected track car
Old 07-19-2009, 07:14 AM
Somatic Negative Optimist
Gunter's Avatar
109k Miles is not enough to warrant splitting the case to replace bottom bearings IMHO.
As for the wrist pin bushings: I f there is no play, or play within specs, I would file the nick a little and leave it.
It's your call.
If the bushing needs to be pushed back into place, use a C-clamp with pieces of ALU or brass for protection. Make sure that the holes for oil delivery line up.
I would do a valve job.
If the cams don't have any galling on the lobes, re-install.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-19-2009, 07:40 AM
Warren Hall Student
Bobboloo's Avatar
Toss up. You could double those miles easily before rebuilding the bottom end but on the other hand a completely rebuilt motor is worth more than a motor with just the top end rebuilt.
It's quite possible, however, that this motor will last the life of the car without ever rebuilding the bottom end. If it were me I think I would probably just remove the rod, clean the burr and re-attach the rod with new rod bolts. I would inspect the rod bearings however to insure that the bottom end is healthy.
Bobby
Old 07-19-2009, 07:48 AM
Definitely going to inspect the heads. probably wise to replace the valve guides at this point and any thing else that needs refurbishing.
So the rods (if need be) can be removed without splitting the case. Thats good news.
Thanks.
Leakproof.
Suspected track car
Old 07-19-2009, 09:03 AM
AutoBahned
RWebb's Avatar
if well maintained, these motors can go 200k or 300k w/o any bottom end issues.
the decision is mainly one of paranoia -- or prudence and depends on the maintenance history of the car...
I did it on my 3.2L (when hotrodding it) but everything was fine - I had no idea of the car's history only that somebody wrecked it and I then bought the motor...
Old 07-19-2009, 11:54 AM
reseal the case and change the intermediate bearings and chain ramps, mike the mains and look to see theyre clean on the surface, let the rods be, just reseal because the same oil clean on the mains is indictative of the rods. The bottom of a 78/79 3.0 is good for 200K +
Bruce
Old 07-19-2009, 01:16 PM
