daily driven 911
im doing the distributor rebuild---NEED PART
im not getting much advance at all so i want to replace the vac advance only thing is NO ONE HAS IT....dealer says its NLA....no one local has it....ive even tried a few porsche only juny places???
\ WHAT TO DO??? my dizzy apart and i kinda need to drive this... any help would be great many thanks
What distributor? What is the bosch number on the side?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
daily driven 911
i belive the part i need is 07180...or long # is 1-237-122-763 its the one with 2 vac ports.
Do people plug the retard one?? i thought i had read somewhere they make our engines run hot?? ![]() if so i can find the one with a single port ( i think ) |
I would rather be driving
I assume you mean an 82SC from your screen name. I have a vacuum module from a 78SC if that will work. PM and you can come by and pick it up.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Wer bremst verliert
Before you replace it, have you verified the advance mechanism is no good? Try reinstalling the distributor and hook up the vacuum port to a minivac or vacuum pump. Check with your timing light if you get advance when vacuum is applied.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
daily driven 911
yea i tested it and got no responce....
what do people do when these go out? are there rebuild kits, or something else would work?? i really dont want to have to buy a whole Distributor $$$$$ ANYONE??
Somatic Negative Optimist
You say distributor is apart meaning: you have cleaned and oiled the center bearing for the advance plate controlled by the vac pod?
Is the vac advance plate moving freely? If the bearing is frozen (rusted), the vac cannot move the advance. Mechanical advance: Are the weights moving the upper half of the shaft freely? No binding? Remove the vacuum pod: Put a short line on the advance connection and suck on it. Can you see and hear movement? Does the diaphragm hold the vacuum? Try this: Distributor service (Clean and lube) real easy without removing the pinion gear!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
daily driven 911
thats what im doing, everything else is cleaned up and good.. it was not advancing when i put vac to it while running....
Are you sure the arm on the Vac Pod is connected to the advance plate?
It takes a little wiggling to get the tab into the pin. Take the cap and rotor off, suck on the advance vac line. You should see a small movement on the plate, not a lot. It also makes a klacking sound. If the diaphragm is good, the tip of your tongue in the line should be able to hold the vacuum. I usually do that before installing the distributor.
grateful user
daily i hate to tell you this, but i think i got the last new one in exsistence. you can have my old one, holds good vac. on the adv. side, leak a little on the retard side, which is no big deal, since most plug it up anyway, sent you a pm
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
ur options are this. The Philbin Group in OR rebuilds them, about 90$
i just got mine back from them, havent installed it yet. right now im running a bosch vac pod off a mercedes i picked up at pick ur part. BTW pick ur part is an absolut CIS goldmine- everything!!!!. the benz one works ok, the advance came on a little fast so have some restrictors in the vac line. problem is they are kinda hard to open up and then get sealed back. believe me i was pissed i emailed bosch in germany and i asked how can u leave us hanging w/no part, klaus had no answer. hope that helps. and yes ive plugged the retard port but ur gonna want it for smog tests
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
