Burint's Avatar
ID if this is the factory slantnose?
Hi,
I found this car at the Porsche center in Bangkok.
I couldn't find the vin in the book.
Is this the factory turbo S?
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
86, 930.
70, 3.2.
67, 911.
Old 07-09-2009, 07:35 AM
the major clue that this car is probably not factory slant is shown by the right side headlamp opening
seen there is the fabricated cover mount that most converters used when fabricating slant fenders with mazda rx7 mechanisms
if you can post a few pics of the inside of the forward portion of the trunk, then we can confirm whether this is factory or done afterwards
also, difficult to be sure, but the rear shock bridge looks like smaller 911 version, not turbo
Does it have the large rear turbo control arms?
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 07-09-2009, 08:45 AM
DP935 member
kycarguy 935's Avatar
It doesn't look like it from the pictures posted. The fender doesn't have the top vents and like Dave said the headlight opening isn't the right shape. I have the same side factory slant fender I am looking at right now and it is different.
It looks like a fun shop there.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 07-09-2009, 09:13 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
The h/l bucket in the fender doesn't appear to be a factory unit (looks aftermarket as Dave said) but the four bolts in the red frame looks like the mounting system the factory used for the h/l motor. Perhaps the tub is an original slant but the fenders not. Better pics of the inside both below the hood latch and the tub sides will determine better.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-09-2009, 10:23 AM
DP935 member
Good point Kevin. I have a spare factory slantnose front clip right here and it does have the 4 holes you have marked in the picture.
I double checked it to be sure.
Old 07-09-2009, 10:41 AM
Forced Induction Junkie
WERK I's Avatar
Originally Posted by Burint View Post
Hi,
It doesn't look like a factory version. If you look inside the bonnet, passenger side, there should be holes for the headlight mechanism. There should also be a support bracket for the heim joint(see pic). I also believe the factory did some reinforcing of the factory panel by the headlight arm mechanism.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-09-2009, 11:30 AM
