-   -   Allignment Question (http://forums.pelicanparts.com/porsche-911-technical-forum/484584-allignment-question.html)
Alan Lindquist 07-10-2009 10:14 AM
Allignment Question
I'm hoping someone can provide some perspective for my 1980 911 SC.
I had new tires mounted in the rear last week and got an allignment. My car handled fine before the allignment and tires. It tracked well on center and was very linear and predictable on turn in and rotation. Right rear tire wear was slightly accelerated compared to left rear. Fronts tire wear is balanced. After the rear tires were mounted and the allignment was changed, I noticed a significant change - not good.
On center, the car hunts. Every road surface imperfection cause the car to move left and right - requiring a minor correction with the wheel. It doesn't feel stable. Turn in is instantaneous and exagerated. As soon as the steering wheel is turned, the car darts that direction and the back rotates a LOT harder than it did in the past. Instead of a progressive rotation, I can feel the tires and suspension load up instantly and the car becomes a lot more sensitive to throttle steer. I noticed that with a full tank of gas, the problem is less pronounced than with an empty tank.
Here are some details to work with:
Stock setup with 190K miles
Front strut bar
Turbo Tie Rods
Closer to Euro than US ride height
Front tires are Toyo Proxis 4 with good tread depth @ 30 lbs
Rear tires are new Toyo Proxix 4 with 34 lbs
Front Left Caster went from 6.4 to 6.6
Front Right Caster went from 6.4 to 6.8
Front Left Camber went from -0.7 to -0.8
Front Right Camber went from -0.5 to -0.6
Front Left Toe went from -0.10 to 0.15 (big change)
Front Right Toe went from 0.10 to 0.15
Rear Left Camber is unadjustable at -0.07
Rear Right Camber is unadjustable at -1.4 (must be that curb that launched over)
Rear Left toe was unchanged at 0.20
Rear Right toe was unchanged at -0.05
Is there a better allignment option? Is there something else to consider?
sbrown.nw 07-10-2009 10:35 AM
How many miles on new tires? I run 34lbs front 40lbs rear after going to 17" Rotas with just below euro height, factory tbars and oversized sways.
Scott
450knotOffice 07-10-2009 10:41 AM
Did a Porsche shop do your alignment, or at least someone who's intimately familiar with old 911's?
Also, food for thought...every time I've replaced the rears only, my car has become nervous. I talked to Tyson Schmidt about it (a well known Porsche guru who used to frequent this board) and he mentioned that pairing old tires with new will almost always produce a nervous car because the rubber compounds and traction characteristics don't really match anymore (aged vs. new), sidewall flex changes, etc. He said that he always bites the bullet and replaces all four when his rears wear out. I do the same now and the difference is like night and day.
Tyson Schmidt 07-10-2009 10:41 AM
Mixing new tires with old will do this. The new pair in the rear need to scrub in and heat cycle before the sidewall stiffness and treadblock squirm begin to match the fronts.
So right now the rear is steering the front, and will feel like the tail is wagging the dog until the rear tires stabilize. It's one of the downsides to rear engined cars. They are very tire-sensitive.
Alan Lindquist 07-10-2009 10:59 AM
That's great advice from everyone. Thanks. I will get a new front set next week based on that information. The rear tires have just several hundred miles on them (one week of daily driving) so they should be well matched when new fronts are added.
Do the allignment specs look right?
And no - it was a tire shop that works on all kinds of cars and doesn't specialize in Porsches. I am tempted to take it to a Porsche experienced shop to set up all four corners with a competitive ride height and a competitive allignment set-up, but I was waiting to add some new bushings and maybe some stiffer torsion bars first.
911pcars 07-10-2009 11:49 AM
Due to the adjustability of our cars, corner balance can contribute to either ill or excellent handling. Consider checking/adjusting when your tire issues are resolved.
Sherwood
burgermeister 07-10-2009 01:12 PM
Rear camber is NOT "unadjustable". It is easily adjusted. Camber of -1.4deg one side and -0.1 deg other side is not desirable. Rear toe-out is also not good for stability - should be slight (15') toe-in.
+1 on replacing all 4 tires at a time. I recall reading in a UpFixin' article (referring to early non-staggered tire cars) that Porsche required new tires to go on the front if only 2 tires are replaced.
304065 07-10-2009 02:03 PM
I agree, take it back to the alignment shop and show them how to adjust the rear camber before you buy new tires.
The self-alignment book used to be available on the dorkiphus site, start there.
Flieger 07-10-2009 02:33 PM
Toe-in also helps keep the car directionally stable. Toe-out makes for quick turn-in but can be "twitchy" on the freeway.
burgermeister 07-10-2009 03:58 PM
Before you take it back to Joe's Tire, consider either aligning it yourself or taking the car to a shop that knows something about 911's. I would not let some random shop put my car on a hoist, let alone start adjusting the rear trailing arm. It's not that difficult to do, but there is opportunity for a clueless hurried greasemonkey to screw things up. YMMV
Bill Verburg 07-10-2009 04:13 PM
Front strut bar
Turbo Tie Rods
front
I like all the caster you can get, 6.5* is great
race cars can use close to zero toe, eevn some toe out but this leads to a darty car, spec is 0 pressed but a little toe in will quiet the car down a lot.
30' to 1* neg cambver is good for a street car
rear
a little more camber than in front 1* to 1* 30' is a good street setting
toe as in the front
Alan Lindquist 07-10-2009 04:26 PM
OK. I'm thinking now that I need to get the car to a shop who can set up a Porsche properly - especially the rear camber. I'll start there and then add front tires. Thanks everyone for your insight. What a great resource.
RWebb 07-10-2009 06:46 PM
have you put 200 miles on the new tires??
Alan Lindquist 07-10-2009 10:51 PM
About 300 probably. Why?
Flieger 07-10-2009 11:16 PM
The tires should be scrubbed-in after 300 miles. I think the twitchy handling is from the alignment rather than the tires.
RoninLB 07-11-2009 12:23 AM
http://forums.pelicanparts.com/uploa...1247297012.jpg
tony9704 07-11-2009 04:51 AM
Ronin,
What years 911 does "pressing" apply to? I just tried to have an alignment done and the shop did nothing of the sorts. Mines an '88. Where did this snippet of info come from please? (sorry to interrupt) Thanks
RoninLB 07-11-2009 05:36 AM
Originally Posted by tony9704 (Post 4771007)
Ronin,
I can only infer up to 1989
front factory specs when pressed
there is a normal tendency for fronts to toe out
aka: adding some toe in compensates for not pressing
RWebb 07-11-2009 11:10 AM
agree - & that's why I asked -- it was one (cheap to fix) thing that could have caused your problem, before getting into other more spendy things to do, as per above
Flieger 07-11-2009 12:39 PM
Please keep your threads together :)
http://forums.pelicanparts.com/porsche-911-technical-forum/484581-allignment-question.html?posted=1#post4771554
