Iowa911's Avatar
Dual Master cylinder question
I am converting to a dual circuit M/C. My question is about the inlets from the reservoir. Is the front inlet for the front circuit and the back for the rears? Logic would say so, but I can't find anything on this. I am in the process of bleeding the new system, the rears went fine, but I am not getting any fluid to the fronts. I'm thinking the inlet tube isn't properly seated. I just need to know which one it is.
Dean T
1984 Cab White/Blue
Cat bypass, B&B muffler, Steve W. Chip
1966 912 Red/Black
1963 356B --sold--
Old 07-26-2009, 03:52 PM
Bill Verburg's Avatar
the reservoir feeds don't matter in the least.
Bill Verburg
Old 07-26-2009, 06:14 PM
Iowa911's Avatar
I messed with this for quite some time tonight. If I crack the bango bolt that goes to the fronts, I am now able to get some fluid when the pedal is pumped. I have checked all of the lines between the calipers and the M/C. I still can't get fluid to come through, either with vacuum or by pumping. What's my problem here? The backs worked perfectly.
Dean T
1984 Cab White/Blue
1966 912 Red/Black
1963 356B --sold--
Old 07-26-2009, 08:11 PM
Is this MC brand new or used? If used (even new), the piston cup/seal for the front system could be faulty. Odds are against both front brake fluid flex lines being clogged, but anything is possible.
Sherwood
Old 07-26-2009, 11:05 PM
Iowa911's Avatar
It's new. I am grasping at straws here, but I have a couple of questions. I have the front of the car more elevated than the back for access to the M/C could this cause any issues? Also, could the actuator rod be out of adjustment cause the fronts to not work? I have the correct rod for the dual M/C, but could it need adjustment?
Dean T
1984 Cab White/Blue
1966 912 Red/Black
1963 356B --sold--
Old 07-27-2009, 07:04 AM
