Fluorescent dye kills A/C ?
An A/C specialist of tremendous reputation here suggests fluorescent dye used to detect A/C leakage would damage the non-metal components in an A/C system. AFAIK, cars with a leaking A/C usually saw fluorescent dye at the shop.
This specialist uses an electronic detector for leakage. Anybody has same experiences or any comments?
'87 3.2 Targa |
Member 911 Anonymous
Well, the dye will take place of the refrigerant so it will effect the cooling process. As far as damage, that seem odd that they would add something that would harm the system?
Logic dictates once leak is found and corrected. One should bleed and vacumm the system and add proper oil and refrigerant ratios.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Guess he's referring to the seals.
He also mentioned that since new refrigerant is very expensive lots of garages use recycled refrigerant of unkown quality/purity, which results in many A/C problems.
'87 3.2 Targa |
electronic detector? I guess you mean the tool which people refering to as the sniffer. I heard using sniffer is more accurate than using dye method, beside dye is taking space in the system.
Fat butt 911, 1987 |
i have a sniffer. nice tool
as far as dye. they have been putting dye in ac systems as long as i can remember. not much is needed. never heard anything bad about using it.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
I've never heard any issue with dye but many AC pros tell you not to use other additives like "leak stoppers".
Maybe the tech was just making the point that his electronic sniffer is a better tool. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
