what is everyones opinion of the Wevo coupler?
any no-slop coupling is nice and precise seems the coupler gets expensive the farther up you go up in design maybe kinda like paying for sprinkles on your ice cream?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Cool. I like sprinkles
I just want to get it the best that I car from the start.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
I'd think most people are correct. Here's what I've picked up so far.
- tighter couplings will increase wear and feel - looser couplings will reduce wear and feel - the reason the coupler is loose is the same reason they tell you not to rest your hand on the stick when you're not shifting; more resistance to the natural movement and vibration = greater wear on the components I'd suspect that the reason aftermarket couplings are round/tight is because they're being marketed to an enthusiast audience, who would rather have a "racey" feel and are accustomed to either working on the car themselves or having parts wear out, and are willing to make that tradeoff. Most people who own these cars and are not what we'd call an "enthusiast" would likely have the dealer replace it with a stock part. Hence no need for aftermarket parts that replicate stock. So, I guess it's what you want. Longevity and looser shifting or tighter shifting and more wear on the components. Your original bushing looks fine to me.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
hey... it's different strokes
I went with wevo sprinkles because I didn't have the time or brains to modify to my licking the precision means that it's easier to bully your way through a 915.. whoops it also means you might have the rhythm to shift a 915 like it's supposed to with confidence and not need to modify stock if it's good enough
T-Shirt wearing, sticker toting, SCWDP registered member ![]() Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it ![]() '83 911sc ROW Targa '84 BMW 320i (what did I get myself into?!) |
i just ordered 6 sets of the black ones with the round hole from pelican. never had a problem with them. the shifter is much more precice, as long as the coupler is adjusted properly. it's a 98% improvement over the slotted ones and with the wevo, you might get the remaining 2%, so there ain't much difference.
Gary R. |
UNDER CONSTRUCTION!
as soon as i find a car with the slotted bushings i take them out and replace with the black ones as well. with some fine tunning you can make a 915 shift very well.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Ironically, the friend who helped me press the new bushings in (round ones) had a spare coupler with new Red bushings - identical to mine. They are not worn, the slop is designed into them.... That said, the issue between black round bushings vs. the red oval ones has not yet been decided... In terms of shifter feel, black wins for sure...as expected. In terms of transmitting less vibrations thanks to built in slop, it's a draw in my book. On smooth road it's the same, on bumps I have a hard time measuring the amplitude of my shifter's vibration while driving straight ;-) Seat of the pants: it's about the same, maybe a tiny bit worse... Of course I have no X-ray vision to determine if the black ones are worse for my tranny... So that bit is done... Next I will install a new early 911 style tranny brace with fresh mounts. I betcha that is my main problem, that old tranny just moves around too much ! |
What do you think of my shift coupler bushings is a question I ask all the girls!
car was a total nightmare to drive before this.Could never relax when drivin it before. On a side note I was driving in 5th gear recently forgot I had my hand on the shifter and it jumped out of gear, I wouldnt say I was putting a lot of pressure on it, but it gets you thinking maybe a certain amount of slack is required. That said difference in car is night and day.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
made my own bushings from AC hose
Cut 2-5/8 long pieces of left over barrier hose from my AC install, lubed them with silicone grease, installed them and they're tight as can be.
There is no free play with these bushings and the shifting feels good. I replaced and greased the two shifter bushings too. Makes the Weltmeister short shifter and old 4speed 930 gearbox alot better. ![]()
Better put a band clamp around the yoke right over the bushings and pin. There is nothing but friction keeping them in and they can extrude out. The clamp works well to keep the bushings in and does not hit the pin or inhibit the shifter.
