911Etarga's Avatar
Bad Coil?
What are the symptoms of a bad coil? My car is running like **** and the only thing that isn't new on the engine is the coil..... It is running on 4 cylinders even after cleaning the carbs, adjusting valves, changing plugs.......and there is an audible random "tic....tic..tic..tic......tic", it sounds electrical, like a spark from the plug, and is coming from the Dizzy/ Coil area.
Any ideas?
'71 911E Targa
Old 06-27-2009, 05:31 AM
al lkosmal's Avatar
That "tic..tic...tic...might be spark, arcing to ground from the dizzy cap, coil wire, plug wires, etc.
Start it up, at night in the garage, with the lights off and see if you have a light show.
Regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 06-27-2009, 05:45 AM
winter
Winter's Avatar
Not sure on a Porsche but in my Audi, (95 S6, with MTM chip + RS2 goodies) a bad coil resulted in a missfire under load (especially under boost, as the car has a turbo). It was a very distinct feeling. Only when the coil has really failed does the miss it appear at idle.
Hope this helps and good luck.
Tom '75 targa
Old 06-27-2009, 06:45 AM
dazed and confused
john baldwin's Avatar
did you find the problem?
Any ideas?
I too am wondering if my coil is bad...same symptoms as yours....
Did you replace the coil?
If so, did it solve the problem?
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 07-18-2009, 11:03 AM
Santa Clarita, Ca.
I had a bad rotor (rev limiting) that was doing that to me. The plastic holding the rear limiting contact was cracked and as the rotor sped up it would randomly make contact with a plug and short.
Old 07-18-2009, 11:31 AM
muck-raker
kidrock's Avatar
If the ticking noise is coming from the coil area, it could be the coil itself, or the lead wire from the dizzy to the coil. Sounds like something is cracked or shorting out.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-18-2009, 11:41 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hey,
Check your coil by removing it and shaking like a can of coke, you should hear the sloshing of the oil inside.
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 07-18-2009, 03:27 PM
porsher
aston@ultrasw.c's Avatar
Often when the coil fails it get seriously hot.
You could wrap it with a cold wet shop towel and see if the misfire goes away.
Old 07-18-2009, 04:18 PM
