Guest
Posts: n/a
Turbo Speed Problems!!
It finally happened!! hit the onramp to freeway in my trusty 930.... car was just feeling oh so good then Arghhhhhh got the old blue light special..... mind was elsewhere as I did not even see him...ticketed for 80+ in a 60... State trooper gave me a break!!!! such are the joys of life....have to re-connect my right foot to my brain tonite, any of you guys have advice on a speed regulator for the brain??
Guest
Posts: n/a
I am currently designing a small device that will fit in your back pocket which is to be hooked up to your electronic speedometer signal wire, which will give a slight shock directly to your brain when you pass the set speed. Look for it at your local Walmart soon.
Mike 86 Carrera t |
Guest
Posts: n/a
Great Mike!! Just what I need!! was thinking of a rev limiter like the indy car guys use also, that way at least the motor would sound so sick the troopers will take pity of me too??
Guest
Posts: n/a
[QUOTE]Originally posted by Bobster:
[B]It finally happened!! hit the onramp to freeway in my trusty 930.... car was just feeling oh so good then Arghhhhhh got the old blue light special..... mind was elsewhere as I did not even see him...ticketed for 80+ in a 60... State trooper gave me a break!!!! Bobster, Maybe you can tell your friends about the new ticket you got and how this trooper did NOT give you a break, LOL Nikki |
Guest
Posts: n/a
I got a ticket in april last year. It was the first time out since the winter. The sun was shining and the car ran beautifully. I felt so good.
Damn it's expensive to feel good...
