Guest
Posts: n/a
2.0 911S ENGINE!!!!
Would someone out there be nice enough to take time and tell me their advance for the following rpm's: 1000rpm
3000rpm I just purchased the HPV-1 system and I want to mach it up to the values from a 911s distributor. The trick here is that I will need the information from the same type of engine as myone. My distributor failed so I couldn't take these readings before removing it. I know that my engine requires 5@0rpm and 30@6000. Thanks for any feedback. louis Miorelli |
