AutoBahned
RWebb's Avatar
tape some thermocouples to all the spots that you "shot" with the IR "Gun"
measure them at different conditions & see how they correlate to the IR thermometer's readings.
what you'd really like is to bore little holes in your pipes and epoxy some thermocouples in to catch the bulk temperature of the fluid. always good clean fun & sometimes worth a MS.
Old 07-19-2009, 09:09 PM
dshepp806's Avatar
This correlation is a good thing to do...put to bed any IR +/-'s related to materials.
Im planning on getting some IR shots this weekend. I intend to make sure the measured surfaces are quite clean (free from coats of "crap") and measure at a similar distance each time (point),..trusting only the specs of the instrument. Now, I'm told the specs are not spec, actually, to reflectivity issues. Will have to look into this for anticipated measuring "slop" with the IR?
A thermocouple won't lie to you (that is, if it's working right...). Time to break out the thermo's on my bench Fluke meter and see what shakes (comparatively-speaking).
Will report back.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-20-2009, 02:00 PM
ShakinJoe's Avatar
Dshepp,
Calibrate your thermocouple first in an icewater bath. Should read.......32 F.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 07-20-2009, 09:12 PM
ShakinJoe's Avatar
Don't get mad T, he won't rent at GT from you.
Old 07-20-2009, 09:13 PM
