Can you hear the front oil cooler fan on a Carrera?
With the engine running, I can't tell. If I leave the key on, does the fan blow with the engine stopped once the oil lines are hot? Which way does the air flow when the fan is operating, forward or toward the wheel?
As you can see, in almost 3 years of Carrera ownership, I have done little. I need to get up to speed on this car or sell it.
you cannot hear it with the car running. it blows thru the radiator, towards the tire. i dont know about your second que. my setup is not stock, and i just wired to a switch.
poof! gone |
Must be a soft fan. I felt under the fender with my hand right at the rock guard louvers and did not feel a lot of heat coming out of the louvers. Some, but not a lot.
I guess I'll stick a candle in there. The Boxster sounds like a street sweeper in front. |
Milt,
The fan does not run when engine is off (no value in that -since only small about of risidual oil is contained in front radiator). It's not really that 'soft' and when it does run the oil temperature has to be above 110 deg C for the thermostatic switch to activate the fan ... You can get a lower temperature switch from the host (made for BMW)
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Milt,
Vash is correct. Also, I'm not sure the the 88 3.2's had a fan. Our '86 had a radiator type cooler but no fan. I added a Turbo oil cooler/fan with the oil temp sensor to activate the fan. However, the stock Porsche sensor activates the fan @ 248F. Too hot!!!Keeps the mechanics busy......... I use the Nason 197F sensor. The fan activates @210F and de-activates @200F. Good luck, Gerry |
I can tell when my fan turns on. my switch is bad so the fan comes whenever it feels like it. I'm not sure i hear the fan but can feel the vibration....maybe the fan bearings are bad. it was annoying so i disconnected the fan
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
The '88s have a fan. When the fan is on a lot of air comes out the bottom, under the oil cooler. It can be heard clearly when standing near the right fender but it is hard to hear when sitting in the car with the engine on. The stock thermoswitch that turns the fan on should be replaced with the BMW part or another switch that turns the fan on at a cooler temp. There is a thread that lists the part numbers for several switches that activate at different temps.
88's absolutely have a fan. I did the bypass mod so I can turn it on when the temp needle starts to creep up, rather than wait for it to get too hot. I can hear it clearly when I turn it on.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Is this the one you mean Jascha?
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-606-118-00-M100&catalog_description=Thermoswitch%20for%20Fan%20-%20Late-Style%20Carrera%20Factory%20Oil%20Cooler%2C%20110-degrees%20Celsius%20(requires%201%20900-123-007-30-M131%20Sealing%20Ring)
John C 1988 911 Carrera coupe 2002 BMW 530 |
Hi Guys,
Not to hi-jack but does the 87 Carrera have a fan? Was the fan first introduced in 88? |
Will program for food
87 does have a fan.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
timeless beauty
My 87 has a fan, it seems that the oil will go the front cooler first.. if that doesn't bring the temps down then fan will come on as temp triggers the fan switch (the above post seems right for temp to trigger fan). Letting the car idle for a long time will trigger the fan, while diving I doubt it comes on at all. The higher the RPM the more cooling, in the summer if I drive it like a sedan my temps are higher then keeping the RPMs above 3k plus its more fun to drive.
Bob 87 targa |
Thanks for the response guys!
No sleep 'til... BROOKLYN
Is there anybody out there subscribed to that thread that can post a link to it? Thanks.
-Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 |
Jim Sims posted these part numbers in another thread.
82 degree Celsius switch BW-61-31-1-364-272-82 91 degree Celsius switch BW-61-31-1-364-272-91 99 degree Celsius switch BW-61-31-1-364-273 I installed the 99 degree Celsius switch and wish I went with the 91 degree switch. Last edited by Jetjockey; 07-18-2009 at 05:02 PM.. Reason: Celsius |
Degrees in Celsius.
Thanks jockey, that 'll do.
Sorry... I was away from the List Here is the BMW Pelican part number for the switch (99 deg C) that is often used as an alternate to Porsche 110 deg C 99 degree Celsius switch BW-61-31-1-364-273 http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=61-31-1-364-273-M323&catalog_description=Auxiliary%20Fan%20Switch%2C%20 2-Prong%20(Red%20Top)%2099%20Degrees%2C%20E24%206%20 Series%20(09%2F82-08%2F86)%2C%20Each
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') Last edited by Jascha; 07-19-2009 at 05:59 PM.. |
The stock Porsche switch activates at about 240 degF....near or at the red zone of the gauge. most people don't notice the fan running because most never get the temps up there.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
| Tags |
| cooler , fan , oil |
