daily driven 911
im doing the distributor rebuild---NEED PART
im not getting much advance at all so i want to replace the vac advance only thing is NO ONE HAS IT....dealer says its NLA....no one local has it....ive even tried a few porsche only juny places???
WHAT TO DO???
my dizzy apart and i kinda need to drive this...
any help would be great
many thanks
Old 07-08-2009, 01:42 PM
304065's Avatar
What distributor? What is the bosch number on the side?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-08-2009, 01:43 PM
daily driven 911
i belive the part i need is 07180...or long # is 1-237-122-763 its the one with 2 vac ports.
Do people plug the retard one?? i thought i had read somewhere they make our engines run hot??
if so i can find the one with a single port ( i think )
Old 07-08-2009, 02:30 PM
I would rather be driving
jpnovak's Avatar
I assume you mean an 82SC from your screen name. I have a vacuum module from a 78SC if that will work. PM and you can come by and pick it up.
Old 07-08-2009, 02:31 PM
Wer bremst verliert
JohnJL's Avatar
Before you replace it, have you verified the advance mechanism is no good? Try reinstalling the distributor and hook up the vacuum port to a minivac or vacuum pump. Check with your timing light if you get advance when vacuum is applied.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-08-2009, 08:02 PM
daily driven 911
yea i tested it and got no responce....
what do people do when these go out? are there rebuild kits, or something else would work??
i really dont want to have to buy a whole Distributor $$$$$
ANYONE??
Old 07-09-2009, 05:46 AM
Somatic Negative Optimist
Gunter's Avatar
You say distributor is apart meaning: you have cleaned and oiled the center bearing for the advance plate controlled by the vac pod?
Is the vac advance plate moving freely?
If the bearing is frozen (rusted), the vac cannot move the advance.
Mechanical advance: Are the weights moving the upper half of the shaft freely? No binding?
Remove the vacuum pod: Put a short line on the advance connection and suck on it. Can you see and hear movement? Does the diaphragm hold the vacuum?
Try this:
Distributor service (Clean and lube) real easy without removing the pinion gear!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-09-2009, 09:00 AM
daily driven 911
thats what im doing, everything else is cleaned up and good.. it was not advancing when i put vac to it while running....
Old 07-09-2009, 11:58 AM
Gunter's Avatar
Are you sure the arm on the Vac Pod is connected to the advance plate?
It takes a little wiggling to get the tab into the pin.
Take the cap and rotor off, suck on the advance vac line. You should see a small movement on the plate, not a lot. It also makes a klacking sound.
If the diaphragm is good, the tip of your tongue in the line should be able to hold the vacuum.
I usually do that before installing the distributor.
Old 07-09-2009, 12:13 PM
grateful user
don gilbert's Avatar
daily i hate to tell you this, but i think i got the last new one in exsistence. you can have my old one, holds good vac. on the adv. side, leak a little on the retard side, which is no big deal, since most plug it up anyway, sent you a pm
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-09-2009, 02:02 PM
ur options are this. The Philbin Group in OR rebuilds them, about 90$
i just got mine back from them, havent installed it yet.
right now im running a bosch vac pod off a mercedes i picked up at pick ur part. BTW pick ur part is an absolut CIS goldmine- everything!!!!.
the benz one works ok, the advance came on a little fast so have some restrictors in the vac line. problem is they are kinda hard to open up and then get sealed back. believe me i was pissed i emailed bosch in germany and i asked how can u leave us hanging w/no part, klaus had no answer.
hope that helps. and yes ive plugged the retard port but ur gonna want it for smog tests
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 07-21-2009, 06:30 PM
