how do you adjust the hood<front>...
Hi
how do you adjust the front hood so it sits lower at the back < where the windshield is>so I get a better contact with the seal.
Old 07-20-2009, 08:19 PM
is there an adjustment for that part??
Old 07-21-2009, 07:52 AM
Registered?
blee's Avatar
The bracket, where it attaches to the body, pivots. Loosen the bolts slightly, close the lid and you should be able to push down on the corners.
Brian
R Gruppe #757
70T Ex-Waterlogged Rust Bucket
http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html
Old 07-21-2009, 08:25 AM
Thanks so much
Old 07-21-2009, 09:15 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
You can also add one washer per side on the forward most bolt between the hinge and the hood. It's a little faster than trying to rotate the hinge base.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-21-2009, 09:26 AM
