ID this 915 gearbox
hello
Could you help me to identify this gearbox ?
it is not a sportomatic. I don't know how many gears it contains
thanks a lot in advance
Old 07-24-2009, 02:04 PM
RETIRED
Joe Bob's Avatar
Can't read the serial number....
2012 ML350 3.0 Turbo Diesel
Old 07-24-2009, 02:07 PM
the picture is a link to a large one. This is the way for the thread to be more readable.
Old 07-24-2009, 02:11 PM
myamoto1's Avatar
Manu - the larger pic didn't help. I could only read a few of the numbers. If you can post the full number, you'd get more help. Or, you can check here:
901(just in case it's not a 915)
http://www.roadglue.com/wiki/index.php?title=901_transmission
915
http://www.roadglue.com/wiki/index.php?title=915_transmission
Josh
85 M491 Coupe - "Fat Bastard"
Old 07-24-2009, 02:27 PM
thanks Josh
I can see _ _ 4 1062
X Y 4 1062
It seems to be a 74' 915 and serial number n° 1062
X would be 7 for a 6 cylinders engine.
and Y maybe a 3 or 8 ?? It is not a sportomatic , so exclude numbers 4 and 6
what about number 5 ?
Old 07-24-2009, 02:39 PM
Old 07-24-2009, 02:45 PM
Peter Zimmermann's Avatar
It's an early 915, looking at the throw out bearing guide tube it could be a late '73, a '74, possibly a '75. Where the "boss" on the bottom of the diff housing is ground down is where the 915 "type" number is stamped. To know for sure remove the diff side cover and count the teeth on the pinion head. 7 teeth = '73.5/74 (7:31 R&P), 8 teeth = '75 (8:31 R&P).
Keep the Shiny Side UP!
Pete Z.
Old 07-24-2009, 02:56 PM
thanks a lot Peter. I am reading your previous posts on this subject
Old 07-24-2009, 03:03 PM
