French Import
zippy_gg's Avatar
Question Engine stand
Given that I will separate the transmission from the engine before hoisting to an engine stand, will a 1000lb engine stand suffice or do I need to go higher?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-25-2009, 11:42 AM
Tadpole's Avatar
A 1000 lbs engine stand will be plenty. You could even get away with a 750 lb stand. I believe that most engines are less than 500lbs or there about.
Mike
'75 911S
'76 911S
Old 07-25-2009, 11:48 AM
French Import
zippy_gg's Avatar
Thank you! That is good news as I may have found a 750lbs stand dirt cheap with local pickup.
Gilles & Kathy
Old 07-25-2009, 11:51 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
You might want to consider a stand that has 2 front legs or bars that come out towards the engine.
It makes it easier to lift an engine onto the stand when you are alone or unable to physically lift an engine with the adapter on it.
I use a jack that raises the engine all the way up to the level of the stand, having installed the adapter on the back, and can slide the adapter tube straight into the stand without assistance.
Bob
Bob Hutson
Old 07-25-2009, 12:32 PM
