How do you stay cool.... with no a/c?
Hi all
Here in the caribbean its always around the 90's
Driving the 911 is very hot and uncomfortable at times
What do other guys do in hot climates
Thanks dean
Old 07-23-2009, 07:16 AM
There are quit few modern aftermarket systems available for most Porsches - even early cars and I've even seen a 356 with cold a/c.
Other are more informed on this than I - living in Southern California and have the Porsche as a third car, I only drive it when the weather is nice - but I see countless adds for a/c systems in the back of the Porsche magazine Excellence.
Good luck.
1972 911T/S MFI Survivor
Old 07-23-2009, 07:19 AM
kent olsen's Avatar
Here in central Florida I have the same issue with my 72 911. I just open all the windows and I bought one of those seat cushions with the little wooden balls held together with fishing line. That at least keeps you back from sweating.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 07-23-2009, 07:21 AM
Bye, Bye.
Scooter's Avatar
We just drive faster with the windows down here in Tejas.
Elvis has left the building.
Old 07-23-2009, 07:23 AM
Super_Dave_D's Avatar
Drive the G35 or the Pathfinder
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 07-23-2009, 07:26 AM
Bye, Bye.
Scooter's Avatar
I've heard of aftermarket a/c, like Rennaire, working well. It just depends on how much $$$ you want to spend. What year is your 911? Some years are easier/cheaper to upgrade than others.
Bollweevil
During the summer I do the windows down bit early in the morning. The rest of the time I drive a car with an actual AC.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 07-23-2009, 07:33 AM
Bye, Bye.
Scooter's Avatar
Jack is right. The Subby has good a/c.
Old 07-23-2009, 07:36 AM
Every time I allocate the funds to update to something like Rennaire, I come up with another area that needs more attention and talk myself out of the upgrade.
2015 Audi S3
Old 07-23-2009, 07:40 AM
I don't want to use the a/c.... as it doesn't work
Was hoping to hear of some way of making the vent fan system better
Or just getting some fans in the car
Old 07-23-2009, 07:41 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Fix the A/C. If it's 90F then the vent fans will blow 90F air at you. Kuehl, Rennaire, Griffiths are three of the aftermarket systems that will make cold air for you..
Gary R.
Old 07-23-2009, 07:53 AM
Fast Eddy's Avatar
I place my hand out of the window in a scoop to bring cool air in towards my face.
Eddy
winter
Winter's Avatar
Fans in the car? Well, you can do that. It will be ugly, and your time and money, IMO is better spent getting your AC functioning as it should. I had an old VW westy with a fan mounted on the dash, that used a toggle switch to turn it on and off, it was tied into the vans electrical system. You could modify something like this and have it hidden behind the dash to boost the air flow through your vents if you are the inventive sort. There are battery powered iterations of these fans, too, which would be less intrusive to your car. Put some down by the footwell or under the dash to keep the air moving about. Or you could get one of those funny hats, with a built in fan and wear that!
Or just roll the windows down and drive like hell!
If you don't want to spend your time and money on your existing AC system, then the aftermarket systems probably won't fit your budget either. Go find some temporary, battery powered fans and attach them under your dash or someplace else. At least you can remove them when it cools off. And you could keep a spray bottle of water in the car and "mist" yourself from time to time. LOL!
Personally, I just take the top off the targa. And I don't wear black in the sun.
Good luck!
Tom '75 targa
Old 07-23-2009, 07:54 AM
ERN911's Avatar
Open window's drive faster
1980sc/ Casablanca Beige
1987 944n/a White
1973E/Signal Yellow/ gone and Missed
1971T/Green/Gone
1988 944n/aWhite/Gone
Old 07-23-2009, 07:57 AM
Immature Member
dentist90's Avatar
I just completed a 3400km trip in the '84. Spent 9 to 10 hours in the car each day and I'll tell you that A/C saved my sanity. After about 10 am each day the heat would become unbearable with the windows/sunroof open, reaching peak temps outside of about 33 C (~90F). There's something about the cockpit design of the 911 that turns it into a veritable greenhouse in the sun, even if you're moving. The (factory) A/C, converted to 134a, did a good job of keeping the cabin comfortable.
In my experience, the factory air in the '84 is quite adequate. I don't know how it is in pre-Carrera cars, but it definitely can keep your melon from baking in the sun. My only complaint is that there are only the two centre dash vents (and the puny side defrost vents) that blow cold. I would have liked to see more side and floor venting.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-23-2009, 08:16 AM
Zeke's Avatar
Racers take out the clock and run a fresh air duct to the vacant opening.
Old 07-23-2009, 08:18 AM
Mine is a 84 carrera too
How much are we looking at to fix the a/c?
I agree it does feel like a greenhouse, I think its the fixed side windows that stop a lot of breeze coming in
Old 07-23-2009, 08:23 AM
Drive with the windows down when it's 80 out. Above that, I take the BMW with a modern AC.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-23-2009, 08:31 AM
Tried driving with windows down but geez that's too much wind draft and wind noise especially over 70...The R12 in my C2 Turbo kept leaking out every year or two so i got fed up,ponied up the money and had the system changed professionally to R134..
I can't wait to pick up the car later today...Mechanic says the A/C will freeze my ass off we'll see
Old 07-23-2009, 08:33 AM
e p slick's Avatar
Cool Suit
Wear a Cool Suit.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-23-2009, 08:50 AM
