BBS Wheel Question
What are the proper offsets for 16" BBS RS wheels in 7's and 9's for a 89 Narrow body Carrera?
Currently looking at 7 et 23 and 9 ET 11
911 Cab
Old 07-22-2009, 06:54 AM
ShakinJoe's Avatar
Correct for Narrow Body.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 07-22-2009, 02:06 PM
Less brakes, more gas!
euro911sc's Avatar
That is good. Also 9 ET 36 with a spacer that came on 930s.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-22-2009, 03:19 PM
I was told I should have ET 15 in the rear instead of 11.
Any thoughts?
Old 07-23-2009, 12:09 PM
Monkey Butt Forespin
84_Carrera's Avatar
Mine are 8 & 9's...
8's - ET28
9's - ET15
Rears, 84 Cab, NO issues... perfect with 245/45-16.
Front, minor / light rubbing, original untrimmed, unrolled flares, 225/50-16
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 07-24-2009, 12:51 PM
KTL KTL is offline
Schleprock
KTL's Avatar
ET+11 or +15 will work. +15 is the most common. I have ET +15 16x9 and 245/45 tires on my car with 14mm spacers, which gives them a net offset of +1. Are you sure of the +11 because i've only seen that on 16x8.
Kevin L
'86 Carrera "Larry"
Old 07-24-2009, 02:18 PM
ShakinJoe's Avatar
Any thoughts?
You are talking about a 4 mm difference!! That is like 1/8th inch and will not hurt anything.
Old 07-24-2009, 02:21 PM
MBruns for President
JeremyD's Avatar
closer to 5/32nd's
Old 07-24-2009, 03:10 PM
ShakinJoe's Avatar
I knew someone would catch that!! I KNEW it would be the Stigg
Old 07-24-2009, 03:16 PM
