Dual Master cylinder question
I am converting to a dual circuit M/C. My question is about the inlets from the reservoir. Is the front inlet for the front circuit and the back for the rears? Logic would say so, but I can't find anything on this. I am in the process of bleeding the new system, the rears went fine, but I am not getting any fluid to the fronts. I'm thinking the inlet tube isn't properly seated. I just need to know which one it is.
Dean T 1984 Cab White/Blue Cat bypass, B&B muffler, Steve W. Chip 1966 912 Red/Black 1963 356B --sold-- |
I messed with this for quite some time tonight. If I crack the bango bolt that goes to the fronts, I am now able to get some fluid when the pedal is pumped. I have checked all of the lines between the calipers and the M/C. I still can't get fluid to come through, either with vacuum or by pumping. What's my problem here? The backs worked perfectly.
Sherwood |
It's new. I am grasping at straws here, but I have a couple of questions. I have the front of the car more elevated than the back for access to the M/C could this cause any issues? Also, could the actuator rod be out of adjustment cause the fronts to not work? I have the correct rod for the dual M/C, but could it need adjustment?
