Member 911 Anonymous
DRACO A5OG's Avatar
Question 84-89 Size of Idle Adjustment Screw Oring
Hey Fellas,
Last couple of days my idle dropped and stayed around 700 RPMs at stops.
I found the O2 Sensor had disconnected, bad crimp, so I reconnected it but the idle was still not where it should be.
Which is odd because I have not messed with it since my last AFR Adjust and Base Setting.
So next step:
I tested my base idle, jumpered at B&C and for some crazy reason the Base Idle dropped to 700 RPMs . WTF???
I prompty raised the RPM's to 880 RPMs but it was being inconsistent when I blip the idle. Sometimes it would go to 920RPMs then I adjust to 880RPMs, Blip then it changes again to 800RPM's.
Then it dawned on me, the Idle Adjustment Screw was Hissing. POSSIBLE VACUMM LEAK? I always thought this was normal.
Then just to test it, I jiggled the screw around and hissing got bad to worse.
Question: do we know the size of the Oring OD/ID?
A thread stated 1/4" Diameter but not specific if it was ID or OD.
TIA
'85 Carrera Targa
PCA/POC
Old 04-14-2009, 08:03 PM
muck-raker
kidrock's Avatar
dude, you are the Idle King. I need to PM you for some idle adjusting Face Time.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-14-2009, 08:33 PM
DRACO A5OG's Avatar
Ah Man, I don't want to be, I just want to drive her, dang it!
So do you know the size of the Oring?
'85 Carrera Targa
PCA/POC
Old 04-14-2009, 08:49 PM
DRACO A5OG's Avatar
Well, just got back from Pboys, well they got a Metric Oring Set but here is the problem:
8MM ID/12MM OD
or
10MM ID/14MM OD
The OEM part appears to be 9MM ID/13MM OD
I used the 10/14, a tight (too tight) fit and the hissing subsided.
Crap, it looks like I am calling Wayne. WIIT, might as well get a cap
'85 Carrera Targa
PCA/POC
Old 04-14-2009, 10:31 PM
muck-raker
kidrock's Avatar
wish I could help you, dude. Seriously, I've wanted to get in there to check out my air/fuel mixture. I've followed some of your ventures into this, because I know relatively little about it. So don't be surprised if you get a PM from me about this in the near future.
STONE
Old 04-15-2009, 08:12 AM
DRACO A5OG's Avatar
Hey No Problem Brother. PM me anytime. If I can help I will.
'85 Carrera Targa
PCA/POC
Old 04-15-2009, 10:25 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Maybe industrial supply?
http://www.mcmaster.com/#metric-o-rings/=1ghl1l
Kevin L
'86 Carrera "Larry"
Old 04-15-2009, 10:26 AM
DRACO A5OG's Avatar
Thanks, I ordered a new Screw and Cap
'85 Carrera Targa
PCA/POC
Old 04-15-2009, 10:50 AM
crashr's Avatar
Hi Draco,
I just replaced my idle screw and it still hisses, so I am assuming this is normal. Did you fix this with a new screw?
1975 Widebody 911 3.2 Euro
Old 08-06-2009, 08:07 PM
DRACO A5OG's Avatar
Yeap, new one hisses too but did fit tighter.
'85 Carrera Targa
PCA/POC
Old 08-06-2009, 09:25 PM
