ckissick's Avatar
Hot starting problem with Webers
I tried the search, but...
I have a 1970 911E with a 1978 3.0L with Webers. Yesterday on a hot day (about 90 degrees), the car wouldn't start after sitting for about 15 minutes. It cranked fast, but no start. I tried, waited, and repeated for about 2 hours before finally towing it to the nearest Porsche wrench. He got in and it started right up.
So what causes this with carbs, and how can I prevent it from happening in the future? It never did it before in 8 years. The carbs are rebuilt and in good condition, and the car runs great once it's going.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 08-13-2009, 08:13 AM
any pumping makes it worse. just open the throttle about 1/3 and crank until it fires.
206 637 4071
Old 08-13-2009, 08:18 AM
Charlie,
John's advice is golden, of course,....
I hope you installed the insulator kit between the heads and manifolds.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-13-2009, 09:19 AM
ckissick's Avatar
I do have the insulators. I had tried starting it the way John suggests, but no luck. The mechanic who got it started said he turned the key with his foot off the gas, waited 2 seconds, then floored it.
Is there anything to be done to prevent it from happening in the first place? (I suppose PMOs would solve it, but too much $$$ for now.)
Charlie
1966 912 Polo Red
1950 VW Bug
Old 08-13-2009, 10:56 AM
66 911 #302694
Arctic Rat's Avatar
Just a thought, had similar starting issues. The problem was from the points being out of adjustment. If your not using points then disregard.
My points had worn enought that they did not provide much of any spark, the engine will crank real easy allowing it to flood,put the proper gap into the points and fired right up ran great.
Good luck
Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 08-13-2009, 12:45 PM
sooty plugs don't help. most carbed engines have them. try some denso irridiums in a hotter heat range. you might look down the 6 throttle bores with a mirror and flashlight after it sits hot for a few minutes to see if any drooling is going on. every engine is a bit different on how it starts the best. maybe yours likes a wide open throttle to let lots of air in.
206 637 4071
Old 08-13-2009, 02:35 PM
At this juncture, it bears mentioning that fuel pressures and float levels must be perfect. Further, one should confirm that the floats, "float" and needles are not sticking.
Today's alcohol-laden fuels are not kind to carburetors and one must be diligent about setup & maintenance.
Lastly, one cannot troubleshoot carburetors if the ignition system has issues. Make sure you have a nice fat blue spark at the plugs when cranking.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-13-2009, 02:54 PM
Bland
unclebilly's Avatar
Is it possible that the carbs have not been drilled to prevent percolation? Could the carbs be percolating them selves dry?
Old 08-13-2009, 04:15 PM
AutoBahned
RWebb's Avatar
Originally Posted by Steve@Rennsport View Post
Today's alcohol-laden fuels are not kind to carburetors and one must be diligent about ...maintenance.
Steve - can you outline the proper maintenance & its scheduling?
Old 08-13-2009, 05:22 PM
Sure,....
Given the physical properties of ethanol and its corrosive nature, its important to:
1) Always store the car with a full tank of gas to prevent condensation.
2) Use a good healthy dose of Stabil in the fuel at all times.
3) Annual inspections of carburetor floats and needles.
4) Annual replacement of fuel filters. We use a filter unit that incorporates a water separator before the carburetors.
Hope this helps,
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-13-2009, 09:04 PM
ckissick's Avatar
Good tips, Steve. But what's Stabil? Did you spell it right? I googled it and just got Adidas shoes.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 08-13-2009, 09:21 PM
Navin Johnson
TimT's Avatar
Sta-Bil
'69 911 GT-5
'75 914 GT-3
and others
Old 08-13-2009, 09:34 PM
Originally Posted by TimT View Post
Thank you, Sir,...
Its a superb fuel preservative.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-13-2009, 11:52 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
hello there all
i have rebuilt a few sets of carbs in the past few months. mine on my 2.7 race car. my car starts in 80 DEG. weather like fuel injection. so two different guys wanted me to rebuild there carbs and make theres run as mine does. all are plumbed the same and vented they all even run the same filters and rain shields.
so one runs great starts ok hot but a 2.2 i cant get to start hot without holding throttle part way down or cranking for 8-10 seconds. it is jetted and synced very well. i even adjusted the valves for him because i thought this might help. no difference. all ignition parts are good timed and it just is hard to start. i think he is a little upset that his car didn't turn out as well as the other two but i cant get it any better. he said it runs better than it has in the last four years and has always been hard to start.
does he just live with the hard start ? he has the insulators between the manifolds and heads. car starts good cold runs well hot.
sorry to hijack
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 08-14-2009, 12:20 AM
Grady Clay's Avatar
Try this:
Originally Posted by Grady Clay View Post
Here are a couple of important links for prior Pelican threads.
“Hot Start with carbs”
http://forums.pelicanparts.com/showt...hreadid=154032
“Weber circulating fuel system”
http://forums.pelicanparts.com/showt...hreadid=205823
The Pelican Search function will yield more.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-14-2009, 05:57 AM
