turbo tie rod ends install. what else do I need for an SC?
just curious, if i pick up a pr of new turbo tie rod ends, what else will I need beside tools to install on an early SC?? thanks in advance guys
My kit came with everything I needed, except for the tools. Install was really easy with Wayne's 101 project book. I very much enjoy the difference in feel. Fun project, especially when re-aligning the front (I had it aligned any way, but was only 1/2 a degree off!).
Al |
yea but i was referring to just the tie rod ends
Turbo tie rod ends will NOT work with standard tie rods!
You should only need the (2) tie-rod ends, (2) spacers that fit between the tie rods and the steering rack, & (2) new boots. If you bought your tie-rods in kit form they should come with everything above. If you just have the tie rod end without the threaded rod that connects into the steering rack, you'll also need the turbo version of the rod. The turbo version eliminates the slop by using a ball and socket connection rather than a rubber bushing as used on the std 911.
-Rich- 1984 911 Track 1985 911 Track/Autocross Last edited by silver911rdb; 08-08-2009 at 05:28 AM.. |
It'll be legen-waitforit
Bump steer kit as well
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
