OZCarrera3's Avatar
Question Loose Wiring Problem - Headlights
My "flash to pass" function on my headlights column stalk switch has ceased to fuction and when inspecting the switch/wiring, I noticed that there were a number of disconnected wires (refer photo below).
I've tried interpreting the wiring diagram in my Haines manual, but am completely 'blind' to the models notation. Can someone please assist me by advising where each wire should be connected? For example, it appears fairly certain that the two solid grey wires connect to each other as apart from their colour, one has a male connection and the other a female. As for which wire connects to which connector on the pull switch, well I'm pretty certain trial and error connection probably would not be a good idea!
Any assistance would be much appreciated.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 08-11-2009, 08:31 PM
OZCarrera3's Avatar
I just spoke to a mate here in Brisbane who also has a 911 to see what his wiring looked like.
Alas 25+ years of tinkering, alarms and stereos means that his wiring is just a screwed as mine. It did highlight however that it would appear that the two yellow wires should be connected (the longer one on mine is incorrectly connected to the light pull/push switchand, the other is loose ) in a loop as it is on his car. Our thinking that this may have been a point for conducting fault diagnosis(?).
Any thoughts?
Sheldon
'07 BMW 335i
Old 08-11-2009, 11:24 PM
dshepp806's Avatar
Is that flash to pass element the only failure you are seeing with so many disconnected wires?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-12-2009, 02:54 PM
OZCarrera3's Avatar
Yep, headlights were working fine except for the flash to pass.
Can any provide me with photos of the wiring looms from thier own car? I just need to know where the two main wires connect (i.e. Red and Grey with black stripe).
Sheldon
'07 BMW 335i
Old 08-12-2009, 03:09 PM
sjmmam's Avatar
Wiring mess
Hello
I live in Brisbane (although my car is stored in Toowoomba) and my cars wiring has not been molested. If you want you can come and look at the wiring and work out what could be wrong.
Regards
SJM
1981 Porsche 911 SC ("Ferdinand")
2003 CBR 1100XX ("Blackbird")
Mercedes C 250 Sports Coupe (Wifes car)
Mercedes A250 AMG (Company car)
Old 08-12-2009, 03:14 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Sheldon,
I'm amazed that with all of those disconnected wires,
you have not detected other anomolies.
If you do not have access to a Bentley manual, your
best bet is to run a "comparison" test with another
car as suggested by SJM.
Bring along a multimeter.
My Bentley is for the 3.2 and would most likely not apply to your situation.
When you perform the "comparison" test, try to
reconstruct that "spaghetti city".
Also, your problem may be in the stalk as these contacts
will, over time, corrode.
There are several excellent recent posts on this subject. (theiceman on Rennlist)
Do a search on "headlights" and, "turn signals" on this forum.
Good luck,
Crown Lager..........
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-12-2009, 03:37 PM
OZCarrera3's Avatar
sjmmam, thanks for the offer, that would be great. I'm heading up to Leyburn for the sprints this weekend, but maybe we could arrange something when I get back.
Maybe if you could photograph the wiring in your car and send it to me that would be the nbext best thing.
I will also have to look at getting a copy of the Bentley's manual asap.
Thanks everyone.
Sheldon
'07 BMW 335i
Old 08-12-2009, 04:33 PM
dshepp806's Avatar
Originally Posted by 86 911 Targa View Post
Sheldon,
Good luck,
+1 on being surprised that you've no other issues with that many disconnects.....we'll have to chase those down...
mmm,
Doyle
Middle Georgia
Old 08-13-2009, 04:20 PM
