-   -   adding fibreglass turbo flares.. cracking? (http://forums.pelicanparts.com/porsche-911-technical-forum/491002-adding-fibreglass-turbo-flares-cracking.html)
StayGold808 08-11-2009 04:39 AM
Hi,
I've got a set of turbo flares in fibreglass. A friend has told me that people are reluctant to add fibreglass flares, as they may crack.
I understand in theory this is the case.
However I'm seeking opinions from people who have added fibreglass flares.
Would you do it in metal if you did it a second time round?
Thanks,
Adam
911st 08-11-2009 09:14 AM
All metal is best choice for finish and resale.
Metal rear with full FG front fenders works to.
Riveted on FG is good for a race car.
Just glassed flairs is concitered a poor soulition and will hurt value.
The exceptin migh be the very wide RSR full rear quarter pannel.
john walker's workshop 08-11-2009 09:42 AM
you will drastically devalue the car.
Dr J 08-11-2009 12:15 PM
I once had FG 930 flares installed on a 911 I used to own. After a while, the ones in the rear ended up showing cracks at the seams. I also had an old mustang and had a fiberglass hood scoop added to it. It cracked at the seams as well. This was all over 10 years ago so I don't know if bonding materials have improved beyond that.
StayGold808 08-11-2009 09:54 PM
Thanks for the replies...
I'm getting mixed information... Some people cringe at the thought of using fibreglass flares. Others claim to have had great success with long lasting high quality results..
Can anyone give me advice on how to prevent seams forming? I have read that some have used glass cloth in between the metal and fibreglass to prevent cracking.
Thanks for your help
Formerly Steve Wilkinson 08-12-2009 05:32 AM
I can't remember ever seeing fiberglass-bonded-to-metal flares that haven't cracked over time. It's a kludge.
berettafan 08-12-2009 05:37 AM
i'm not seeing any mixed info here. fiberglass is good for bumpers, hoods and race cars.
you wanna go 'streetable race car' with it and put on glass flares with dzus (sp?) fasteners then you're talking.
wowzer911 08-12-2009 05:48 AM
For the DIY'er fiberglass could look more appealing due to the ease of installation, but you should be prepared to replace/repair them as they will eventually require it.
Me, I picked up a MIG, have been doing a little practicing, and will go that route.
StayGold808 08-13-2009 07:21 PM
I've read some posts, including those by KevinP73, who seems to have had good long-lasting results with bonding fibreglass flares.
I think it comes down to using the latest technology in adhesives, which have improved considerably.
rattlsnak 08-13-2009 07:25 PM
If its done right, you will have no issues with FG. My last 4 cars were all bonded FG rear flares and have had no issues. We have put 100s of them on at the shop and never seen an issue. One day we jacked up a car with a block of wood under the rear FG bonded flare and it held fine. .. (long story) !!
skinnerd 08-13-2009 07:30 PM
Fiberglass is just not a very "elegant" way to go.
I'd save up your pennies until you afford steel flares.
I know they are expensive new, but you can usually find good used sets come up for sale for decent prices.
Everytime your tires fling a rock into those fiberglass flares, you'll be getting little star shaped cracks that will drive you crazy.
If something bumps your fiberglass flares, they'll crack or break no matter now great the spaceage adhesive is.
They just aren't durable enough.
At least steel can always be banged back out reasonably easily.
Steel for sure is the way to go.
J P Stein 08-13-2009 07:58 PM
I can see using FG flares for a race car. Attach them with the thought that they are expendable. If you're gonna spend the big bucks on a nice paint job on a street car, I'd use steel.
StayGold808 08-14-2009 12:24 AM
As stonechips are always a problem with widebody cars, I was planning to stick a small section of clear plastic at the fronts of the rear flares. I've seen this done on another 911 and you couldn't really tell it was there without looking closely in sunlight.
Anybody done this?
Ove 08-15-2009 01:06 PM
I've heard of people glueing neoprene fabric / wetsuit fabric on to the inside of the fiberglass flares to prevent this.
As the others said the finish will be better with steel flares. Be prepared to spend more money/time to fit and prepare FG for paint than the steel ones.
One benefit of FG is the reduced weight compared to steel. Personally I would not fit FG flares to steel fenders to save only a few pounds. But I'm thinking of replacing the entire steel front fenders with FG fenders. The weight saved by this makes the fit/finish issues acceptable for me.
skinnerd 08-15-2009 05:43 PM
Exactly Ove.....I was talking about hitting the underneaths of the fenders, not the leading edges.
You would need to come up with some kind of defence against this.....never thought about wetsuit material.
Still like the thought of steel over fiberglass.
RoninLB 08-15-2009 09:02 PM
I've done glass work on surfboards, boats, etc for years. One of my fav acts is shooting a thin coat of Imron directly on the glass without primer which has helped me in avoiding paint stress cracks on whole glass projects.
whether you're lucky enough to avoid fender glass to metal paint cracking or not, glass fenders Only belong on a 911 track car imo.
MarKoBrow 08-16-2009 04:28 AM
I have bonded Flares with high grade epoxy on five cars so far and have never suffered cracks. once done under coating will protect the underside.
not_hans_stuck 03-16-2011 02:24 PM
Read my thread.
Both are fine but there are caveats.
Just so you know, most people want to buy unmolested cars. So, even if you ask less for your car than a comparable unmolested car you may find it hard to find a buyer. The pool of potential buyers for modified cars is much smaller than for all stock.
Personally, I didn't care, so I hacked it up, and I will continue to do so. It's my car, and I'll keep it.
Fore-warned is fore-armed.
Hope that helps.
H
Wil Ferch 03-16-2011 02:56 PM
You might try gluing steel flares to the body...as a compromise...
See esteemed Gunnar Racing....go to their site
http://www.gunnarracing.com/
click on "projects".....
... then click on "completed projects, pg 1"...
... .then click on "RSR Turbo conversion"....
...... then go to dateline 11/27/01...
and find recommendation for Duramix 4178
petevb 03-16-2011 03:26 PM
I have a fair bit of bonded CF on my current one, and did have bonded FG on a previous car. Everything below is higher quality carbon, not FG:
http://forums.pelicanparts.com/uploa...1300312962.jpg
Carbon is better than FG- stiffer, better matched thermal expansion which helps with cracking issues, etc. It is not steel, however. If you know where to look a join line is still visible on my car at certain temperatures because carbon expands at a different rate than steel. "Print through" of the fabric is also sometimes visible if you look hard for the same reason. Cosmetically an all steel car will be superior...
Having had both I wouldn't bond in FG; carbon for max weight savings or steel are the options I'd choose between. If I did bond in a fender I'd do it as on my car. For a pure street car I'd vote steel.
http://forums.pelicanparts.com/uploa...1300314329.jpg
