Bland
unclebilly's Avatar
Engine Back in Car
With help form Andrew15, I decided to refresh my 2.7 instead of putting the 3.2 with G50 into my track car.
The engine was a stock CIS 2.7 with back dated exhaust and pertronics. It ran great but I hated getting passed on the straights by just about everyone.
The engine is now running 9.5:1 JE pistons which cc'd out to 9.8:1, DC40 cams, stiffer springs, Weber carbs with 34mm venturis, same old school exhaust but with a Bursch muffler.
The car is also all repainted now - I had an unfortunate incident during a wind storm this winter where the temporary car shelter pounder the hell out of my car during take off before crash landing in a neighbor's field 1/2 a mile away.
A forklift is a handy tool for all sorts of stuff...
So my first Solo1 session is on Monday. I just have to reinstall the windows, bumpers, interior, hook up the oil lines, install roll bar, regrease the cv joints... I think I'll be running the C4.
Old 05-29-2009, 10:32 AM
Bland
unclebilly's Avatar
More parts put back on... just need to figure out how I'm going to mount carerra cooler up front.
Old 06-02-2009, 10:08 AM
Bland
unclebilly's Avatar
Sunroof, Front Spoiler, Back Window, Rear Spoiler in place...
Old 06-08-2009, 07:30 AM
zugelassener benutzer
teamfee3's Avatar
Nice, would look even better with a set RUF wheels or biga** Fuchs.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 06-08-2009, 07:47 AM
Bland
unclebilly's Avatar
I have Lindsay Racing Wheels for it... 2 need fixin' tho.
Old 06-08-2009, 03:07 PM
Bland
unclebilly's Avatar
At the track...
photo taken by my buddy, Mark Shalanski at Stratotech Raceway near Edmonton, Alberta.
Old 08-09-2009, 07:38 PM
Send a message via AIM to fintstone
Verrry nice looking engine. Paint looks great!
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 08-09-2009, 08:57 PM
spence88mph's Avatar
looks great, excellent color choice, glad you ditched those 993TT wheels, I just don't like them on 911/930s.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 08-09-2009, 09:09 PM
tb912's Avatar
Wow. Those wheels look SO good. Perfection.
1968 Light Ivory 912
1974 BMW 2002
Old 08-09-2009, 09:10 PM
So, how dose the new motor run?
Old 08-10-2009, 07:45 AM
Tom '74 911's Avatar
I'm really interested too in your new motor. I am in the same boat you were in - I have a 2.7 CIS that runs fine, but would like more HP. Interesting that you chose to stick w/you 2.7 instead of doing a swap to have more displacement. Did you notice a difference after the refresh of your 2.7?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 08-10-2009, 07:53 AM
Bland
unclebilly's Avatar
The car runs great. I am running 34mm venturis and am likely going to switch to 36mm and bigger jets.
There is little power below 3000 rpm but this works out OK with thr 77 gearing. You are on cam in 4th and 5th at highway speeds. You can't drive 50 mph in 5th gear anymore - you are lugging it.
The HP is very addicting. To do it again, I would go with a rev limited in the MSD (6AL instead of 6A) and not run the speed limiter in the rotor. The engine should make power to 7000 rpm but the cut off is at 6500. The car pulls very hard at 70 MPH without downshifting. I also had my distributor recurved to mechanical advance RS spec.
Thanks for the compliments - the wheels actually came with the car - they are ROH wheels that I sand blasted and rattle can'd with black metalic semi gloss paint. Thet look much better black than they originally did. I only switched back to these becasue I got a good deal on 17" R-Compound rubber.
The engine is alot louder - if you plan on daily driving, you probably want to keep your sound deadening pad. I am running the Bursch muffler and it sounds great (don't believe everything you hear about the Bursch).
Old 08-10-2009, 02:58 PM
19 years and 17k posts...
azasadny's Avatar
Very, very nice!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-10-2009, 07:39 PM
Very nice Scott, quite an upgrade, both performance wise, and looks wise.
Robert
Currently Porsche less (but the wife has 2)
Old 08-11-2009, 04:23 PM
