The Puff.
Mr.Puff's Avatar
Originally Posted by gsmith660 View Post
You are a busy soul aren't you, it is easier to pull both the tranny and motor for future reference. It takes me about an hour to pull a motor and from the time I mate up the tranny to the motor to motor in the car and mounts tight is about 45 min. by myself. One note if you spun the motor at all with the tranny separated then you will probably need to put the tranny in gear and spin the axle hub to get the splines to line up again.
This car has to be back together by the 31st. We did spin the throw out bearing... I'll keep that in mind when we are trying to get the wishbone thing back in place.
It will get done!
--Puff
'70 CT1B
'11 GTS 300 Super
Old 08-15-2009, 09:24 PM
The Puff.
Mr.Puff's Avatar
Originally Posted by zippy_gg View Post
I am going to ask you the same question she asked you last night: Is it in yet?
I'd prefer hearing that from a lady instead of my current lady-less situation !
'70 CT1B
'11 GTS 300 Super
Old 08-15-2009, 09:25 PM
Happiest when Tinkering
gsmith660's Avatar
It will get done!
--Puff
Not the throwout bearing the axle hub so you turn the input shaft in the tranny. I know you will get it done good luck.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-16-2009, 05:48 AM
Somatic Negative Optimist
Gunter's Avatar
Thumbs up
This car has to be back together by the 31st. We did spin the throw out bearing... Huh? I'll keep that in mind when we are trying to get the wishbone thing back in place. Huh?
It will get done! Hmm............but will it run?
--Puff
Keep us posted about your progress.
A Pelicanite nearby may be able to help?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-16-2009, 07:54 AM
The Puff.
Mr.Puff's Avatar
Ahhhh, :S. Kind of makes you wonder how I got the thing out.
'70 CT1B
'11 GTS 300 Super
Old 08-16-2009, 04:36 PM
The Puff.
Mr.Puff's Avatar
Hehe, I'll keep that in mind. Just be warned that my car has a taste for blood. It cuts me once a day .
'70 CT1B
'11 GTS 300 Super
Old 08-16-2009, 04:38 PM
The Puff.
Mr.Puff's Avatar
It's back in! Never mind the dangerous and precarious positions that resulted in victory .
--Puff
'70 CT1B
'11 GTS 300 Super
Old 08-17-2009, 12:57 AM
gsmith660's Avatar
Good, glad nobody got hurt sounds like it was harrowing I hope you took notes and lessons learned for future drops, I did the first time. My biggest oops the first time was not hooking up the engine ground left me scratching my head for hours. The last time I thought I had the clutch fork engaged in the throwout bearing good thing I tried to hook up the clutch first and found it very loose didn't lose much time as a result.
Old 08-17-2009, 03:20 AM
jkh2cpu's Avatar
Good going, Mr Puff. My factory manual says to take the engine and transmission out as a unit. Try that next time as I'm sure it has to be a lot easier, and in the end, quicker. You might check out the device that our sponsor sells for removing the engine on a floor jack. I bought one, and it IS easier that what I've done for the past 30 years.
Good Luck!
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 08-17-2009, 04:00 AM
gsmith660's Avatar
Good Luck!
Do you have a pic of your motor and tranny on the support I was curious how that little thing would balance the whole package, I have been using a ATV kack lately but I will admit it was easier with the floor jack to balance everything. I usually end up pulling the motor by myself as none of my friends are availible to get greasy (none are motorheads or porsche fanatics) but love to ride when I get done.
Old 08-17-2009, 04:09 AM
