No voltage 2nd stage rear window defogger relay.
I'm about to wire my rear window defogger, but noticed that the relay is not giving any voltage on the second stage connection (see pin 3 in diagram below). In the electrical diagram one can see that there exists an "solid state" unit.
I think this is the problem, but what is it for? And how can I get it to work? I need this since I'm going to use these connections to turn on two separate functions. (defogger and motor compartment blower (got no heater controller??)).
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I have been flogging this issue for about a year!
Having bought two replacement relays with the same results as you are having, I finally contacted the folks @ Hella. The issue is that relay #2 on the PC board is not being activated by the solid state circuitry. My best guess is that relay #2 is on a time delay, or cycle profile by the circuitry in order to prevent rear window fracture. As you can see by the attached diagram, all voltages and ground are present. Additionally I verified element(s) continuity. Resistor R1 is most probably a factory adjusted setting for a time constant circuit. Email me and I'll go into the details with you. ![]() ![]() ![]()
Ah, that makes sense. Thanks for your response and offer gerry50, but I think I can work it out from here on.
I was going to tie all defogger elements together, but that doesnt seem to be too sensible with the potential cracking and all. Than I have to find another way to activate the engine compartment blower, since I got no heater controller (relay). Any suggestions? |
Oh, im sorry. I meant gerry 40 off course. Yes, I'm wondering if the separate staging is really necessary? Although, I dont want to take the risks in the winter (with normal temperature I think it makes no difference).
I got a 3.2 and looking at my motronic EPROM it should be around 84. |
The two stage is indeed necessary as the center element will not adequately defog your rear window especially if you have a Targa, and live in a very cold climate.
The only time we use ours is on winter trips to the mountains. However, having friends at, and visited the factory on several accassions, I assure you that the "Porsche Coats" are very thorough folks. They put that two stage in for a reason. The earlier 911 (2.7's) had a two position switch on the dash board which, had time out problems. Lots of fractured rear windows. |
Im a believer myself when it comes to true purpose of components in Porsches. I have a two position pull switch too (besides off), but it is not a targa. However, I will wire it in the correct manner in the near future.
I got a workshop manual (84-89). I dont think its a Bentley. The heater controller relay and its socket is completely absent, at least the 12 pins version. So is the middle/armrest console. I discovered a bundle of wires and a round relay (5 pins) in the engine compartment fuse box. I think it is and older blower system or so: bundle towards relay: red / white (one of the pins of relay, always hot 25A fuse 2 ??) red / black (one of the pins of relay, always hot 16A fuse 1 ??) yellow or white / green (bundled, but not connected to relay) bundle from the relay (only 4 wires) red / white red / black yellow / black (to connector of the blower with brown as ground) yellow Questions remain: - which of the wires is the control wire - to what should this wire be connected (dashboard temperature slider or something ???) Last edited by bigpino; 06-27-2009 at 05:24 PM.. |
How about the fresh air blower? I took it out to oil it and after installing it again it blows maximum in all positions. The diagram shows some switches to shunt the resistors. What is that all about?
Bad transistor, probably. just check all of the components values/integrity,...replace as necc. Looks to be quite the simplest of circuits.......have you checked (measured) them?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia Last edited by dshepp806; 06-28-2009 at 05:45 AM.. Reason: content |
dshepp806, if you refer to the fresh air blower (luggage compartment) then there are no transistors involved. The dashboard slider got some slide contacts and the blower got some resistors as you can see in diagram above.
However, what are those switches parallel to the resistors. They seem controlled by nothing??? In my case they are all short circuiting the resistors, since all positions of the slider result in maximum blow. |
ok, the whole wiring for the engine compartment heater blower works. However, I still havent figure out what will switch it on (yellow wire).
I read something about the mid 'console' heater levers (red) pulling up will connect the blower as well. I have the levers, but does anybody know where the switch is? |
Caveman Hammer Mechanic
I am on the same rampage, my engine compartment blower turns on when turn the key on, and will not shut off until I turn the key to the off position. Relay logic? missing switch somewhere? eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 06-28-2009 at 10:14 AM.. |
Eric, does pushing down the heater flap levers turn off the blower? Do you have a 5pins round relay or a 12pins box relay? In the meanwhile you can pull the blower relay just to shut it up.
I had 2 yellow wires connecting each other near the handbrake lever (going into the beam where the shift couple is). Between the connection a switch should be placed, but I got no idea where that switch should be. Unless, one should have a 'climate' control in the mid console. Last edited by bigpino; 06-28-2009 at 10:32 AM.. |
eric P.S. 5 pin round
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Got a 5pins as well. What I can remember I wired it as follows
bundle from the relay (only 4 wires) pin 30 - red / white (alway hot fuse 2 25A engine compartment fuse box) pin 85 - red / black (switched hot, I have search for one in engine compartment and added a fuse) pin 86 - yellow (if grounded than blower will turn on, still dont know where the switch is) pin 87 - yellow / black (to connector of the blower with brown as ground) pin 87a - not connected
Hey,
I pulled the parking brake, no heater wires or switch. Went fishing under the dash, on the 3 lever climate control there is a 12V yellow with red stripe that is hot when the switch is on and dead when the red lever is moved to the right side of the car. FWIW eric
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Time to break out those (blower) schematics,...let's see.......... Doyle
ok, sorry for that. Fortunately, the yellow/red is a candidate. I will have a look later for that. If it's the same I have to rewire pin 85 and 86.
In your case, you should remove the relay and see if terminal 85 or 86 is 'connected' by that yellow/red (put e.g. a lamp on). If it does then the complimentary terminal should --I guess-- be permanent ground. If all checks then I guess your relay is stuck (maybe should check that first). |
I am looking at the Porsche "flow diagrams" and looking for the actual switching signal. later eric
Ok, Doyle. That makes more sense
. In the meanwhile it gives 12V so I connected center element to 1st stage and upper and lower elements to the 2nd stage. I haven't checked what the exact interval is of the 2nd stage, but it is on right at moment I turn on the 2nd stage. Any idea what the interval is. Is it a matter of seconds or minutes?
