Throw it on the ground!
Engine wants to die upon removal of oil filler cap?
My recently swapped 3.2 wants to stall upon removal of the oil cap. Old engine did not do this. Cause? Solution? Suggestions?
Additionally, the idle feels a little rougher than it should be. Set up with SW Chip, Cat bypass and stock muffler. Mechanic/friend put his hand at the muffler outlet and said that it has a little miss. All plugs are new and injectors were sent to Witchhunter.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-18-2009, 05:04 PM
Oh Haha's Avatar
Did you re-install the restrictor in the oil breather line?
I'm not 100% this would cause the other issues but it should stop the stalling when removing the oil cap. Huuuge vacuum leak.
Pacific Blue
Wayne
Old 05-18-2009, 05:07 PM
Zeke's Avatar
What did you keep from the "old" motor? If not the ignition and intake, you could have all new issues to start with.
Old 05-18-2009, 05:09 PM
dezzmo's Avatar
My car does the same thing.
Whenever I remove the oil cap to check the oil level it would begin to run a little rough but it would never stall. I'm running SSI's with a SW chip.
I did the engine swap about 3 years and it's always been like that. I'm guessing it's normal for these 3.2 motors to do this because it runs perfectly
EarlyS 1017
RGruppe 663
73 911T 3.2
01 Ducati S4 Monster 00 Ducati 996
Old 05-18-2009, 05:24 PM
Milt, my new engine was complete except motronic unit under seat. I did not remove the intake to replace the intake gaskets as all looked good and all barrel nuts were tight.
Mark
1987 911 Coupe
Old 05-18-2009, 05:26 PM
dshepp806's Avatar
Is the restrictor in place?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-18-2009, 05:32 PM
Doyle
Everything went back together as it was. What/where is the restrictor you and Oh Haha are referring to?
Mark
1987 911 Coupe
Old 05-18-2009, 05:37 PM
scottb's Avatar
Motor dies when I open tank to check oil
1984 Targa
Doyle
Doyle, I posed this earlier today looking for the part # for this reducer which is cracked. I just saw a similar post by you.......I this where the "restrictor" is?
Help with part # please
PN: 930.207.229.00 "Check Valve"
Mark
1987 911 Coupe
Old 05-18-2009, 05:51 PM
Check valve pictured here: Note crack in rubber reducer just above lower clamp & no clamp on upper line
Mark
1987 911 Coupe
Old 05-18-2009, 06:00 PM
Just to update this thread......problem diagnosed at Dealership as intake leak on cyl #2. Sure would have been easier to replace the gaskets while the engine was on the stand. So much for assuming they were OK.
Oh and if this was not enough, tech said that the valves could stand an adjustment as several are loose - so much for my first valve adjustment!
Mark
1987 911 Coupe
Old 06-03-2009, 06:56 PM
You probably still have the restrictor missing in the hose from the tank to the front of the curved hose going into the throttle body.
The gaskets on the heads will collapse allowing an air leak into the intake..been there done that.
Bruce
Old 06-03-2009, 07:19 PM
Bruce
Where is the restrictor? You got a pic or part #?
Mark
1987 911 Coupe
Old 06-03-2009, 07:40 PM
Oh Haha's Avatar
Man , that was a biotch to find but here it is:
part 10a in the diagram
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_78_83_KATALOG&Illustration=104-00&Line_Item=10
Suggest pulling the line off and see if it's in there before ordering a new one.
Pacific Blue
Wayne
Old 06-03-2009, 07:52 PM
Thanks for the link.....I don't recall seeing that part in the line. Perhaps it is in the line on the engine I removed. I'll check.
Mark
1987 911 Coupe
Old 06-03-2009, 08:45 PM
Thanks guys. Just checked. No restrictor in new line. Old restrictor still in old line but is does not want to come out. Mangled it a little with needle nose pliers trying. Guess I just order a new one.
Mark
1987 911 Coupe
Old 06-03-2009, 08:59 PM
Oh Haha's Avatar
Cool.
Glad to hear your problem is being resolved.
Pacific Blue
Wayne
Old 06-04-2009, 05:14 AM
78-911SC's Avatar
Will the performance of the engne be effected if the restrictor is not in place or just when you open the oil cap?
PJ
78 911sc Targa
70 911T
Old 06-04-2009, 06:34 AM
Oh Haha's Avatar
You would have, in a sense, a vacuum leak without the restrictor. It'll run but will run better with it.
Pacific Blue
Wayne
Old 06-04-2009, 07:08 AM
ruf-porsche's Avatar
I think that is normal. By opening the oil cap you just created a huge vacuum leak.
Old 06-04-2009, 01:52 PM
