Torque Questions
I have just removed my oil pressure sender, and I can't find most of the torque specifications for when I re-install it. I need 1) the 17mm through-bolt that holds that goes through the support piece, 2) the 14mm nut that screws into that, 3) the 12mm nut that screws into the oil pressure feed line, and 4) the 17mm nut that secures the feed line to the case.
From what I've read, most of these are a "feel" torque, but I always worry about my feel. It's always too much. The washers involved are crush washers, right? So, they should be pretty darn snug? Finally, is there a way (other than a crow's foot wrench) to make sure the sender is torqued to the support piece correctly. At least I do have the number for that one. Thanks for your help.
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
Alan,
Tight, but not too tight... Bruce |
