Old 60's Porsche Tech
captainlewis's Avatar
Question Oil pressure indicator light sender 85 Carrera?
What do you need to take off to get to this switch to be able to replace it, any tricks? I can barely see it, JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 04-07-2009, 01:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OK, just repaired this.
It is hell of alot easier to have the engine out but here it goes:
The switch is located right behind and below the AFM connected to a 1" diameter wiring harness. It literally sticks out with a green wire and a female stab that goes onto the switch.
Check to insure the wire is still attached to the harness. Mine was severed and luckily just loose attached to the switch. Well again not so lucky.
Wrench charged me my left kidney to fix it. All he did was splice it back together. Voila I have the IDIOT light again.
The engine was out for tranny replacement.
'85 Carrera Targa
PCA/POC
Old 04-07-2009, 05:20 PM
Drive like you stole it!!
Paul491's Avatar
I'm not pirating your thread, but was wondering if you guys might have any ideas about my '84 Carrera's problem... Oil press light and both brake warning lights all come on at once - together! The oil press and oil level is good, temp is normal. The engine is running fine; I drove it home 15 miles on the fwy.
Could it be a sending unit or something grounding out? Any ideas would be greatly appreciated. Thanks
Paul491
”People willing to trade their freedom for temporary security deserve neither and will (soon) lose both.” ~ Ben Franklin
Old 04-07-2009, 09:00 PM
wesayso's Avatar
Did you find out what happened? I had the same behavior today during a traffic jam at lower revs in a '82 SC. Oil temp, level and pressure where all normal. I'm suspecting the pressure sender is at fault as the light first flashed only at 1200 RPM and when I got home it was completely on even at 2500 RPM. My brake warning light was showing up at the same rate but I figured they are tied together for better visibility? Oil temp didn't affect the behavior as it went a bit lower once I was driving at normal speeds.
'82 911 SC
Old 08-28-2009, 01:06 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
JL,
I went "back there" last month to replace a breather hose.
Here is my post to another member.
But first review this wiring diagram to possibly resolve your anomoly by trouble shooting a loose, or broken wire.
My approach to your issue would be:
1. Remove the oil pressure gauge from the cluster.
2. Remove the Green/White wire from the gauge.
3. Place a ground on the gauge connector which normally holds the Green/White wire.
With the ignition on your oil light should light up.
If it does, there is an open circuit between the sending unit and the gauge,
or the sender is defective.
If it does not, check the bulb, and the 12V to the gauge.
Next, with the Green/White wire still disconnected, make a continuity check from the Green/White wire to ground with the engine running.
No continuity re-confirms an open wire or defective sender.
pm me as required.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-28-2009, 02:21 PM
