1981 911SC Targa
1981 SC (ROW) Rev Limiter/CD Box Questions
My engine has developed a miss (fuel or Ign.) at around 4000 rpms all of the sudden. I have read up on 20 or so things that could cause this but I am still not sure and do not want to spend a ton of cash chasing this gremlin. I am pretty sure it is a fuel issue because it pulls like a freight train in first gear then in second is when the hesitation starts.............like the fuel is being cut off. Questions: I read that ....... The USA SC's have a rev limiting relay up in the front, behind the oil pressure/temp gauge. It cuts power to the fuel pump. Could this be my issue? Another post I read..........stated that the SC's from 1980-83 had the rev limiter installed into the CD Box. Another one .............rotor that is the rev limiter ...........(which mine does not have) but should it or not? Another stated that .............the fuel pump relay could be bad.......is this located under the dash or in the engine compartment? Any help would be much appreciated. ![]() Thanks Frank
Frank 1981 911SC Targa 1967 Buick GS-400 |
Frank, Sounds like could be a fuel issue. Mine is an 82 ROW SC and I had the same problem until I took her to the local Bosch tech who sorted out my fuel pressures and adjusted my CIS now no more problems till I hit about 6200 rpm which I have been told is the max I will see. Which is fine as I can get 120 mph in 4th at that then slide her into 5th.....
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
ROW 81 SC should only have a rev limiter in the rotor. With a US rotor in a ROW SC, it'll rev till it blows up...not cut out prematurely. I just put a '78-'86 Turbo rotor in mine - extends the rev limit to about 7300. At the track this weekend I verified that it works.
- '72 911T - '81 911SC Euro |
The stock 6-pin Bosch CDI boxes do not have a rev limiter installed. The only box (to my knowledge) from Bosch with a rev limiter is the 935 8-pin CDI unit. And that is unobtainium.....
Your issue is either a fuel (mixture) issue or fuel delivery (fuel pump, filter, releay) related. If it only happens under load and at 4000 RPM it could also be the advance mechanism in your distributor being balky. Have you check that? Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
I was always under the impression the limiter is built into the SC tach
Bruce |
Ingo your right on the dizzy as well that was another of my problems. Cleaned mine up as per instructions from I think Gunter, and reset timing. Remember ROW cars shoud be set to 25deg BTDC at 4000 rpm with vacuum line disconnected.
See attached for more detail
1981 911SC Targa
Thanks you all, I will get back with you after I check the fuel pump relay and the fuel pump.
I read Gunter's post on the "Distributor Service" and that is something I will do this weekend. Sit tight and I will let you know how it goes. Thanks again
(BOSCH) Rotor Part Number - 1234332223
or 930.602.901.01 - Rotor, 930Turbo 76>79 3.0 & 3.3 7000Cutout
1981 SC Targa Euro - Minerva Blue 2003 Audi A4 1.4T 1999 Audi A4 1.4T - Hers |
Also physically check that your cable is plugged in snuggly to the CD Box
