need dizzy expert
after learning that the aluminium dizzy and the cast steel dizzy have rotor and cap that do not interchange , i have an even deeper mystery ,, i have 2 dizzy both have the 0231 121 005 but the markings are different
1 has marking on the tag that says made in germany and on the body near the connector there is a marking that say ( 5 degree v OT) written vertically
the other has a tag that says germany then under ( importe d allemagne) in french but there is no marking near the connector
its for an original 914-6 , which one is better and why
thanks in advance
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven
011850275 911S soft window targa next in the garage
2000 S4 stage 2
660R stroked
Old 08-17-2009, 06:15 PM
I'm no expert but what engine is involved?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2009, 06:18 PM
dizzy
its for an original 914-6 engine , rebuilt to factory spec 100% original , and once you recomend , i would really like to know why one or the other and what the difference between the two
2000 S4 stage 2
660R stroked
Old 08-17-2009, 06:30 PM
maybe start with researching the ignition curve of each until you sort out the housing?
also maybe the carb engine dizzy came with a vacuum advance or no vacuum pot and the fuel injection came with a vacuum retard?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2009, 11:40 PM
dizzy
guys read the info before replying
the advance curve , I have it and its the closest you get to an original-6
the advance curve again , its the same part# , therefore the same curve
both have a centifugal avance , again same part number
why is the marking different, one in english the other in french and what does the 5 degree vOT means,
i know about TDC but v OT, on the english label one
i would try them both , but in a -6 its a big B to swap unless you are some sort of 4 arm troll!!!!!!
2000 S4 stage 2
660R stroked
Old 08-18-2009, 06:13 PM
