Senior Advisor
James Brown's Avatar
carb setup pictures please
I am changing from the dreaded CIS to the dreaded carb setup and would like to see engine pictures to get ideas on how people ran fuel lines, return lines, wiring, oil breather, ect...
seems like a good time to make the engine bay look sharp! Race cars are welcome also!
"It's the little things that make it special"
08 Cayenne Turbo
Old 08-20-2009, 04:55 PM
Fuel line setup
Here's my setup. After the regulator it goes up and "T"'s off to the carbs, no return line.
Old 08-20-2009, 05:10 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Here's mine still in the doner car and a bit of a mess.. that's a Holley pressure regulator behind the pump, no guage (and i'm replacing both it and the pump with a stock front mounted pump and a PMO regulator)... HTH
Gary R.
Old 08-20-2009, 05:32 PM
al lkosmal's Avatar
carb setup
Here you go James,
RGruppe #669
http://www.x-faktory.com/
Old 08-20-2009, 08:12 PM
Senior Advisor
Mike- that is just sick! nice job!
Gary-like the twin plug setup, what's it going into?
Al- I have to come over and see that, looking good and thanks for the parts they worked great.
keep them coming guys
looks like im going with the SC fuel pump and a PMO regulator, a couple of filters.
should I keep the CIS fuel filter in place? (fuel tank, fuel pump, fuel filter, regulator, return, two fuel filters, carbs, 2-3 psi at the carbs).
08 Cayenne Turbo
Old 08-20-2009, 11:22 PM
