Power Socket (lighter) Plug-In Voltmeter
I am having issues with an erratic tach. A search indicates that it could be caused by a loose wire, bad tach of voltage regulator/alternator issues.
So, I thought I'd start by checking the voltage being put by the alternator with integrated regulator. And I found this cigarette lighter plug-in digital voltage regulator on Amazon: http://www.amazon.com/Vector-VEC008-Digital-Voltmeter-Volt/dp/B0002ISEQW It shows: - Measures Voltage Output on Running Vehicle - Plugs Directly Into Vehicles Power Socket - No Battery Required - Designed for All VehiclesReads from 0 - 24 Volts - High/Med/Low Voltage Indicator Lights Show the Battery's Overall Condition Plus its only $12.99 & eligible for FREE Super Saver Shipping on orders over $25.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Why not just get a decent Multimeter?
Also, either my cheap inflater or the Porsche Cigar lighter socket is non standard.
Rick 88 Cab |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Sergio,
You can buy a good Fluke 77 on ebay for about $75. Great for around the house, and around the car. We have one. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Formerly known as Syzygy
Probably your lighter socket is non-standard. The hole is too big, right? I got a little plastic adapter piece so that I could plug in my hair dryer, beer fridge and uber-wattage hand held light for night time squirrel hunting exploits. And of course, for my radar detector until I have a power cord hard wired...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I have the vector and am pretty happy with it. Just remember that the socket size for the 911 is larger. I ordered the european adapter for proper fit.
http://www.escortradar.com/store/european-adapter.html I have a multimeter, but when your by yourself, this is pretty handy. eric |
Sherwood |
I bought a Fluke years ago at an electrics swap meet (yeah they got them for other things besides Porsches) plus a cheapy HF meter to carry in the car and the plastic ring thingy for the lighter socket. I also have a small VDO 914/944 voltage gauge that I was going to mount under the dash (one of these days).
I wanted the plug meter so that I could easily read the voltage while driving the car. My tach is acting up intermittently. Works fine sometimes and at others what it reads has no correlation to the engine's rpm. So it could be a loose/corroded wore (easy fix), a bad tach (send it to NH) or the alternators with integrated VR (pull it from the car and have it rebuilt). I'm hoping the meter will indicate which to do. I just got a kick out of how cheap these plug in one have gotten. Years ago, I spent more at RatShack (Oops, it;s now just "The Shack") for a plug in the had just three lights (green/yellow/red) to indicate the condition of the battery. This new one has that plus ("But wait, there's more!"), a digital read out of the voltage. And I don't have to pay for shipping if I bump my Amazon order up to $25? Is that right? Well, lets throw in a book I've been wanting.
Platinum Member
Easier to catch the LEDs out of the corner of your eye than driving around with a meter. I may get one also. I just went nuts with my GPS, thinking it was defective, but I think it may be an intermittent connection on the socket, as it works fine in another vehicle/another socket.
FWIW, I bought an adapter from Radio Shack that plugs into the cigarette/power port and has two screw fittings on it to which I can attach the probes from my voltmeter. I also use it to put 12 volts INTO the system when, for example, I'm changing the battery and don't want to lose my radio presets.
It works well, and I think cost less than $10. Scott
1984 Targa |
AutoBahned
connect a data logger and log voltages at various points in the wiring as you:
start the car on a winter day same for summer day run it around town run it with headlights on bright and then let it sit for 2-3 weeks - both summer & winter that should be a good start |
Where can I get a data logger for $14?
Have you a radar/laser detector that can provide voltage readouts? That's what I do with my Passport.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Doyle, great suggestion.
I've got a Valentine1. Does anyone know if it provide voltage readouts?
