tune carrera...help
i have an 88 carrera. (live in san jose ca. 95127). tryin to locate fellow porsche owners, who would be willing to help me tune my carrera. (dont expect...for free.) re;plugs, valve adjust. etc. if you live reasonably close and can help. i d greatly appreciate..... thanx. john 408 204 4899
Old 08-09-2011, 02:57 PM
I can come help but not for about 2 weeks, I'm going to Bonneville. I live in Saratoga and work in Berkeley during the week so my time is limited in the San Jose area.
Plugs, cap and rotor is a good place to start along with valve adjust.
Do you have floor jack, the lifting tool and jack stands/etc. Level place to work?
If you just bought the car you may want to change all the fluids/etc.
Other: fan belt, air filter, fuel filter, new plug wires (Magnacor), dme relay
Other stuff to check/do: brake pads, change brake fluid.
PM me if you want to connect, you might find others that can come over sooner.
Old 08-09-2011, 04:19 PM
There are lots of fellow pelicanites here in the bay area. Just set a date i'm sure someone will show up and give you a hand for a beer and pizza.
91 964 Guards Red
64 356C Ruby Red
85 Carrera (Gone but not forgotten)
Old 08-09-2011, 07:05 PM
hi thanks for info. i bought car 6 yrs. ago. but cannot keep putting out 1000. s of $ for tune ups. i chg. oil reg. dme relay. etc. im a bit a miss about valve adjust. fuel injection, timing etc. id welcome your help whenever that may be. i appreciate your response. thanx j. cell 4082044899
Old 08-09-2011, 09:27 PM
If you ever make it to Fresno, we can do the whole shebang in a few hours, gratis labor.
Old 08-09-2011, 09:33 PM
In the mean time you might list exactly what you want to learn, just valve adjust and spark plug change? As long as you change the oil(s), keep valves adjusted if it runs OK then the durability is probably covered... right guys? I guess there is a long list of things that should be done and a short list. Long list might include repack front wheel bearings. If the engine and trans are healthy then the big ticket items are covered. That's my 2 cents. Others here know a lot.
Old 08-09-2011, 09:48 PM
Drisump's Avatar
I'm a thousand miles away so I can't offer any in person guidance, but you may want to go over what has actually been done on the records you have for the car. According to Porsche, a valve adjustment should be every 15K, along with fuel and air filters, plugs, rotor/cap, oil and filter and a certain amount of inspection (belts, hoses, etc.) Porsche also recommends change out of the brake fluid every two years, in my climate I have followed this to the letter as brake fluid actually will pull water from the air. You are lucky to have such a wealth of willing and experienced people nearby. Cheers
Old 08-11-2011, 05:54 AM
