alternator warning light
Hi Everybody, I have an 1989 3.2 Carrera. It has developed a problem with alternator warning light. This started as an intermittent fault and now seems more permanent. With the engine running the warning light is usually out, but if I turn the indicators on or the reversing light the warning light comes on the rev counter needles drops a little as does some of the other gauges. The indicators do not come on and there was a noise coming from behind the revcounter. I have not as yet tested the with a voltmeter whether the alternator is charging at this time. My question is , is this and alternator problem or should I be looking else where. Thanks for any help with this.
Old 08-25-2009, 12:48 PM
SC-targa's Avatar
Sounds like the alternator or voltage regulator is failing.
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 08-25-2009, 12:50 PM
dshepp806's Avatar
Get a meter on it soon to "see" what's going on.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-25-2009, 04:45 PM
