alternator warning light
Hi Everybody, I have an 1989 3.2 Carrera. It has developed a problem with alternator warning light. This started as an intermittent fault and now seems more permanent. With the engine running the warning light is usually out, but if I turn the indicators on or the reversing light the warning light comes on the rev counter needles drops a little as does some of the other gauges. The indicators do not come on and there was a noise coming from behind the revcounter. I have not as yet tested the with a voltmeter whether the alternator is charging at this time. My question is , is this and alternator problem or should I be looking else where. Thanks for any help with this.
Sounds like the alternator or voltage regulator is failing.
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
Get a meter on it soon to "see" what's going on. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
