-   -   PLS help identifing my engine (http://forums.pelicanparts.com/porsche-911-technical-forum/496186-pls-help-identifing-my-engine.html)
Rebel911 09-02-2009 05:54 PM
Rebel911 09-03-2009 04:22 AM
bump
MJHanna 09-03-2009 04:53 AM
want to sell it?:D
Rebel911 09-03-2009 05:02 AM
that is the plan, you looking to buy? I am going to put it on ebay today after work
tonythetarga 09-03-2009 05:02 AM
Originally Posted by Rebel911 (Post 4873853)
the engine number is 6399095
thanks for the help.
Well, something doesn't look right but I could be wrong. The 639 indicates it is a model year 1969 911 S but the 9095 indicates they made over 9000 engines with that series. My info shows engine range is 6390001 to 6392126.
Look beside the number and check for the engine type. Should be 901/07 or 901/13
MJHanna 09-03-2009 05:07 AM
Honestly it does not look correct you sure you copied the number correctly?
639001-6392126 are 69 s engines 2.0, your 6399xxx does not compute. They only built 2126 S (the last one I own)
Serial number breaks down as:
First digit 6= 6 cylinder
Second digit = engine type
1=t
2=e
3=s
3rd digit model year
9=69
0=70
1=71
Then the sequential number
Your number is to high 639 (9095)
MJHanna 09-03-2009 05:12 AM
even the T and E engines did not go that high for a serial number T s stoped at 6198184 and E's at 6298583
Rebel911 09-03-2009 05:18 AM
MJHanna 09-03-2009 05:27 AM
like Tony said you need to look for the engine type. Should be 901/07 or 901/13.
Can you post a picture of the whole engine?
Rebel911 09-03-2009 05:39 AM
Don't knock the silicone, this is the way I got the engine. I decided to go another route.
http://i690.photobucket.com/albums/v...5/P9010426.jpg
http://i690.photobucket.com/albums/v...5/P9010427.jpg
http://i690.photobucket.com/albums/v...5/P9010428.jpg
http://i690.photobucket.com/albums/v...5/IMG_3893.jpg
Rebel911 09-03-2009 05:42 AM
this is what it cam out of:
http://i690.photobucket.com/albums/v...5/P8300390.jpg
http://i690.photobucket.com/albums/v...5/P8310413.jpg
MJHanna 09-03-2009 05:46 AM
its an SC 3.0 engine
Rebel911 09-03-2009 05:51 AM
I am looking to confirm that this is a ROW engine like the rest of the car.
tonythetarga 09-03-2009 05:54 AM
I personally can't tell if it is a 2.7 or 3.0, but it is a CIS injected engine. Someone may have stamped in numbers from a factory replacement case, which does not come with a number. The red shroud and 639 appear to have been intentionally misleading.
YOU NEED TO IDENTIFY THE ENGINE TYPE BY THE NUMBER BEHIND THE SERIAL NUMBER.
Rebel911 09-03-2009 05:57 AM
tonythetarga 09-03-2009 06:04 AM
Originally Posted by Rebel911 (Post 4874674)
Tony, you are like 5 miles from me. I am off the Lake Rd. in Webster.
There are a lot of p-cars in this area and a great group of track junkies. With Watkins Glen and Mosport so close to us, these historic tracks are a blast to drive.
What engine plans do you have for the car and why not use what you have?
Rebel911 09-03-2009 06:10 AM
I currently have two engines and the other one is top secret till it is done. :cool:
tonythetarga 09-03-2009 06:15 AM
Well, if you want to know what the other lump is and have the ability to bring it to a shop, go to Eksten's at 78 Bennington Ave. 585.621-8200. Larry is the owner.
(Bennington is off of SR18 behind Kodak....not far from Adrenalin ********)
Rebel911 09-03-2009 06:31 AM
thanks
Rebel911 09-03-2009 10:12 AM
