Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
Question Hunting idle
Hi all,
I am suffering cold start issues and hunting idle on my '83 SC. When I start the car it stalls and does not hold idle unless I step on the gas pedal. I have also some hot starting issues, although they are less frequent. The car is a stock '83 SC with 160.000 miles on it.
I am thinking the WUR is the main suspect here. What do you think? Any other options besides replacing it ($$$)?
Thanks!!!!!
Paco Anton
83 SC Targa (Euro)
Old 09-10-2009, 01:07 PM
2002 996 C4S
jcsjcs's Avatar
Idle Control Valve?
Idle Control Valve Testing Procedure
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 09-10-2009, 01:16 PM
Designer King
Paulporsche's Avatar
Aside from the above, the WUR is probably the most likely candidate, along w/ vacuum leaks and an incorrect mixture setting.
An idle that hunts rhythmically (like a sin wave) in a CIS engine is usually from a too rich mix. One that drops and then comes quickly back up, holds and then drops is usually from a too lean setting.
You have to determine if the mixture is just set incorrectly, or are there other things wrong that someone has tried to rectify by changing the mix.
A CIS fuel gauge is an important tool in finding out if your WUR is OK. An AF (air/fuel) meter is good for checking the mixture.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-10-2009, 01:40 PM
Drive it like u stole it.
jonesb930's Avatar
I had this exact issue with my car a few years back. It was the WUR. I used the CIS fuel pressure gauge set to prove this out before ordering a new one. The gauges are under $100 and well worth the money if you plan to play with CIS cars. On a side not, after I replaced the WUR I took it apart and found it was full of junk. I cleaned it out and reassembled it. About a year later I sent it to a friend that was having a similar issue with the same part number. It fixed his problem.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 09-10-2009, 07:35 PM
