Idle Control Valve Testing Procedure
I'm redoing my vacuum system, and wanted to check to make sure my ICV is working properly. I searched and didn't see a procedure on this site or on Clark's Garage, so I made one.
I also added it to my site, which can be seen here. My site is kind of like Clark's Garage, except I don't have nearly the number of articles he has, but I do try and take more pictures than he does. This is part of my complete vacuum replacement of my '86 951, which I hope to make a writeup for. Anyway, here's the writeup (minus the long introduction): Quote:
Proprietoristicly Refined
Damm! you are a busy man
![]() Very nice. I have been using this link in the past-- Idle Valve Thanks again. John_AZ |
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Ok, I performed the above test on my ICV and everything seems OK. Until I realized that my valve is mounted 180deg. from how TexasBlake has his mounted in the clamp.
So now the question begs - whose is right? Which direction should the arrow be pointing? I'm hoping someone can also cite a source. I'm assuming everyone will say there 944 is running with it one direction so it must be right, but since both of ours seem to have been pulled in different orientations, I'm suspecting that it either doesn't make a difference - or it led to one of our followup problems. Can anyone quote or paste a page in the factory manual that has this tidbit of information? Jim 1985.5 944 NA |
For posterity purposes, I did find out they arrow was to point to the conenction of the intake plenum/s-hose (toward the firewall). Good luck! Jim |
