mdoherty
Guest
Posts: n/a
Post idle variation on C4
My 92 C4 has an idle that is very sensitive when first started. If the gas pedal is pushed and then let off, the car almost stalls but recovers just in time. In addition, the car has poor throttle response for the first 4-5 minutes of operation. Basically it acts like the mixture is to lean. I'm suspecting a the mixture flapper valve is dirty or sticking slightly. Anyone have this problem?
Old 03-26-2001, 07:38 PM
Nickshu
Guest
Posts: n/a
Cool
Could be that. Check the Temp sensor on the left cam cover as well, I think it should read 2000-3000 Ohms when stone cold. May not be sending the correct information to the computer on cold starts. Also check the inline fuse for the preheater on the 02 sensor. A blown fuse here can also cause wierd cold start behavior.
Good Luck.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 03-26-2001, 09:31 PM
dsentel
Guest
Posts: n/a
Post
I'm pretty sure that when my floormat gets pushed up toward the gas pedal too far, it causes a similar condition. I forget the technical explanation (a mechanic told me this), but it is easy to check and try it.
Old 03-27-2001, 06:31 AM
john walker's workshop
Guest
Posts: n/a
Post
find a shop with a bosch "hammer" and do a system adaptation. this often straightens out odd running problems.
Old 03-27-2001, 08:12 AM
