Are vacuum assisted brake bleeders needed on 911
I was at WGI this past week and a Instructor trying my car thought my brake pedal was soft. I told him I had just bleed the brakes via speed bleeders. His comment was all 911 brakes need to be bleed with a master cylinder vaccuum type device in order for all air to be removed. Your thoughts?
Old 09-10-2009, 05:16 AM
I prefer to use a combination of BOTH methods. The vacuum works well but I feel better knowing the pressure from the MC is pushing the fluid out. I guess I am a belt & suspender type of guy.
Old 09-10-2009, 05:31 AM
Bill Verburg's Avatar
You can do it either way, I use a m/c pressure bleeder at home, but don't carry it on the road.
vacuum bleed is a third way to do it, many don't like this method because air can bleed back into the caliper if the lines to the nipples aren't tight
Bill Verburg
Old 09-10-2009, 06:27 AM
Southern Class & Sass
Dixie's Avatar
You do not need to do anything special to bleed the brakes on a 911. Pressure, vacuum, gravity, or pumping the pedal all work just fine.
May I ask what fluid and pads you are using, and if you have ducting to the front brakes?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 09-10-2009, 02:02 PM
T77911S's Avatar
i use my wife. most of the time just gravity. i had a cap with a shreder valve and would put that on with about 2-3 psi to do it by myself.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-11-2009, 05:03 AM
muck-raker
kidrock's Avatar
says here to be careful to _not_ depress the pedal to the floor while pumping the brakes. Hope this is not the case with your brakes.
BTW, I like Speed Bleeders. Very good and simple concept.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-11-2009, 09:45 AM
