kqw kqw is offline
TDC "Z1" mark???
I adjusted valves this past weekend. Found TDC and the Dissy mark match up. Did the 120 degree rotation and sequence of 1,6,2,4,3,5.
However, isn't TDC supposed to be marked with a Z1 stamped? Where exactly is it stamped?
The Fox
Carrera
Old 04-14-2004, 02:26 PM
keithdog72's Avatar
Send a message via AIM to keithdog72
TDC should be marked Z1 and it will be on the rear (closest to the bumper) of the crank pulley.
1975 911 Targa
1972 VW Beetle
2004 Mercury Mountaineer
2003 Suzuki Intruder 800
Old 04-14-2004, 03:25 PM
My '88 Carrera has a Z1 mark (same location as Keith says), but not my '77... maybe some cars just don't have the mark.
But even if it's not marked, you can always tell which of the 120-deg marks is TDC/BDC Z1 because there is a timing advance mark next to Z1 and not next to the others.
Having just completed the adjustment, I suspect you knew this already, though.
Old 04-14-2004, 03:42 PM
kqw kqw is offline
Thanks folks,
I'll look next time to verify....
The Fox
Carrera
Old 04-14-2004, 03:47 PM
keithdog72's Avatar
Maybe the experts can clarify here, but I thought that ALL factory pulleys were marked. Could it be that aftermarket pulleys don't have Timing and TDC nomenclature on them?
1975 911 Targa
1972 VW Beetle
Old 04-14-2004, 07:47 PM
Friend of Warren
My pulley is factory and I sure can't find any Z1 stamp on it.
Kurt V
Old 04-15-2004, 06:03 AM
KTL KTL is online now
Schleprock
KTL's Avatar
My factory pulley with provision for A/C (two pulleys) just has the marks and no Z1 lettering. When I replaced the double pulley with a single one, the new single pulley does have the Z1 mark on it. Go figure.
Kevin L
'86 Carrera "Larry"
Old 04-15-2004, 06:16 AM
ViRu1220's Avatar
I found out my pulley doesnt have the z1 mark and i had to use the distributor and just figure out the notches. i did notice the tdc did have the timing notch right before it.
frank
Old 04-15-2004, 06:33 AM
Recently there was a thread on this subject with nice pics...I can't find though. I think JDub was asking.
Warren & Ron, may you rest in Peace.
Old 04-15-2004, 06:36 AM
Crotchety Old Bastard
RarlyL8's Avatar
Mine also has no Z1 stamp. After finding it with the dizzy I painted the correct notch with a dab of left-over guards red. You can see it now!
Old 04-15-2004, 09:01 PM
Jays72T's Avatar
No z1 mark on my car either and was planning on posting the same question. Thanks.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 04-15-2004, 09:12 PM
keithdog72's Avatar
Great Idea RarelyL8. I always "borrow" some of the wifes nail polish to mark. Definitely a good idea for those who dont have a marked pulley. just in case you have to pull the dizzy and forget to mark it. Those are the kinds of tips the new guys should be reading.
1975 911 Targa
1972 VW Beetle
Old 04-15-2004, 10:35 PM
kqw kqw is offline
Dang, you guy are determined to have me open the hood again......(thanks)
'Honey, can I use some of your nail polish, there's something I must do to the car......"
She doesn't believe me when there is a legitimate reason. This is going to confirm ALL of her suspicions......
The Fox
Carrera
Old 04-15-2004, 10:43 PM
1970911T
Mine has two marks unlabeled so which is which? Is the 5 degree timing mark on the left or right side of Z1 ? I thought the timing mark would be on the right side of Z1 (I have a 1969 911E motor) so it would be BTDC but I have seen pictures where it is on the left of Z1 (ATDC)
Old 09-13-2009, 11:35 PM
docrodg's Avatar
Some car is BTDC... some were ATDC so just check the service manual and go from that, or the pretty gold foil labels.
Don't use nail polish, too girly. Just slap a strip of duct tape on it
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-13-2009, 11:40 PM
rnln's Avatar
before or after?
frank
Fat butt 911, 1987
Old 09-14-2009, 12:33 AM
rnln's Avatar
Mine looks like this but no mark, letter, nor numering. I think the first one of the left is (where it marks Z1 on this pic) is TDC. Am I correct?
Fat butt 911, 1987
Old 09-14-2009, 12:38 AM
E Sully's Avatar
'86 Carrera Z1 (TDC) location on '87 Carrera
Old 09-14-2009, 06:36 AM
15 deg after TDC
5 deg after TDC
Z1 is TDC (as close as one is going to get without using a dial indicater on the piston.
35 deg before TDC.
Old 09-14-2009, 07:37 AM
