Yes, your ducktail appears to be a factory made part. It could also be from '73, either from a later RS or a spare part purchased from a dealer.
Here are some photos of the frame from an AL ducktail. Does your frame have the additional, small square piece of sheet metal spot welded to the interior of the frame in back of the holes for the rubber tie downs? This is a good indication it is the real deal.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
i have to take a look, do the steel and alum backs have the same reinforcement, thanks louie
hotvwnut |
Hi Louie,
I have not examined a large # of these original parts but have own(ed) three different ones, one AL and the other 2 steel framed. They all have these metal reinforcements added.
Restore your Duck Tail
If you'd like that Duck Tail restored give me a call. I make the metal base glass top as you see in the pictures.
Gary Stratton Stratton Motorsports (407)421-1911 |
Sonjay, do you have any ducktails for salel?
1979 911sc owner in San Diego. My first post and story on the Pelican Forum can be read here - http://goo.gl/7WZjp My favorite website can be viewed here - http://goo.gl/MPWUA Thank you, this is a great forum!
The '74 duck would NOT have the license plate light holes of the "73
Not always the case. I have seen original '74 Carreras with their original ducktails that had the cut outs for lights. These holes were filled with a metal blockout plate in each hole, held in place by 2 screws for each plate.
This is consistent with Porsche's pattern of using up existing parts until producing a modified part, in this case a metal frame with no dugouts for lights.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe Last edited by fryardds; 12-02-2011 at 06:01 AM.. |
As Johnny Carson used to say: "I did not know that"
